SdrPlay RSP1 and DSD 2.242 FMPP.exe [Can't open SDRPlay device #1]
inside
Hello.
Anybody except me is get any similar error?
SDRPlay device with serial number 1 is not present or is already in use
This error i take only in FMPP.exe. I try many versions, but SdrPlay API 3.06 may be forbid use China clones of SdrPlay ?
thx.
morfis
Do you have the correct 10 digit serial number of the SDRplay device entered in the fmpp.cfg file?
If using multiple SDRplay devices the serial numbers should be separated with ", " (without the quotes a comma then space).
Has the SDSRplay device already been 'claimed' by another piece of software?
inside
Yes i am insert real s/n in to config file.
Also i have way for replace sn to other, and with other sn situation still same.
About Sdr# , SdrConsole ets.. all this software work fine.
Anybody is have older SdrPlay API instaler with 3.03 or 3.04 api plz ?
morfis
Another possibility is that the dsd+FL won't work with an RSP1 - people have used 1A and 2 and here it worked with the duo.
I still have a copy of the "SDRplay_RSP_API-Windows-3.04.exe" installer in my downloads though I think you can download the older API as part of the old ExtIO download direct from SDRplay
inside
In SdrPlay download can get 2.1 and 3.06 only. Can you upload SDRplay_RSP_API-Windows-3.04.exe to sendspace.com ?
R0am3r
Salt Water Conch
Oneida County, NY
I too have tried to use my SDRplay RSP1 with DSDPlus FL. I reached the same conclusion - you need 1A or newer. Thus, my RSP1 has been relegated to working as my Kenwood TS-590SG pan adapter.
thewraith2008
Something you said caught my eye:
Are you saying you are using a fake SDRPlay device?
If so, then your problems probably stem from that.
DSDPlus Fastlane 'Notes.txt' mention FMPP is only for SDRPlay RSP2 devices but it does seem work for RSP1A devices.
Not sure if RSP1 ever worked.
FMPP v1.0, v1.3, v1.4 most likely uses SDRPlay API version 2.13 (NOTE: v1.3 and above don't work with any version of DSD+ below 2.176)
FMPP v1.6, 1.8 uses SDRPlay API version 3.04
FMPP v1.9, v1.11 uses SDRPlay API version 3.06
morfis
....Can you upload SDRplay_RSP_API-Windows-3.04.exe to sendspace.com ?
I have no idea what sendspace.com is but still beleive your problem is related to the device being RSP1 architecture. I haven't seen anyone reporting success in using those with FMPP. The replies from R0am3r and thewraith2008 would seem to support this conclusion.
inside
Hi, About RSP1 - is no matter, Chinese Clone or Original. Because all this copy 1:1 from 3$ TV Dongle with MSI001 Chip!
Also i cal replace S/N to anyone what need.
I need API version 3.04 install, and older FMPP v1.6, 1.8 software, can you upload everywhere like sendspace.com ?
Hope this can help me.
And one more things, i use Clone RSP1 with myself designed RF BandPass Filters, and i get Sensitivity + SWR to much better that on original RSP 1 where Filters developed - by childs.
inside
FMPP v1.4 ask API 3.03
FMPP v1.6 ask API 3.04
FMPP v1.9 ask API 3.06
I am need 3.04 Api , hope the help me .
inside
Solution able for DSD 2.256 and FMPP v 1.13 with Api 3.06
start FMPP -rc -i1 -o20001 -f[freq] -M3 -L5 - where is LNA=5 , IF=13
start DSDPlus -r1 -e -T -E -i20001
example file.bat
start FMPP -rc -i1 -o20001 -f425.100 -M3 -L5
Not Topic can be Closed!
Thanks all for Attention!
