SDRPlay @ SDR Console (Prroblem)
What's your version of SDR#? The plugin requires SDR# v1411 or greater.
1423 if I recall ..
It is not installed right now. I gave up on the SDRPlay.
I have yet to find any software that works well for VHF/UHF and that is what I want it for .. as I have no HF antenna.
WyoDuner
Las Vegas, NV
AA few thoughts on this rather bizzare thread.
Saint, you said you tried everything and can't get your SDRplay to work. It doesn't seem like you tried different software. HDSDR works great and pretty easy. I use SDR Console too and it is more complex but it also works great - the very latest version (released in last week or so fixed a lot of issues). SDR Sharp works as well but... well, you know...
edmscan, you said you would rather stick to your scanners because the SDRplay is deaf on VHF and above. I can't speak for yours of course, but I find sensitivity is great on everything from HF to UHF. I have done comparisons to my Kenwood TS-2000 and the SDRplay picks up everything the kenwood can. I have several antennas - HF, VHF, UHF, 800 Mhz, Discone and all of them produce the results they should when coupled with the SDRplay. I regularly use mine for amateur satellite communications - not something you can do with a deaf receiver.
You both complained of trouble with SDR Console. Why not try HDSDR? Easy to use and works well for everything.
Like KF7YN said - don't run the gain too high especially if you are in an urban environment. SDRs give us a lot of flexibility but there are pros and cons too that wide bandwidth and sensitive receiver. If strong local stations are present you may need some filtering on any of these lower priced SDRs.
People are trying to offer advice and help but I get the feeling some people would rather not accept help and just blame software and/or hardware when both the hardware and software are working great for 99% of the people.
I got my feet wet with a the RTL SDRs and was blown away by the whole SDR thing. I doubt I will spend thousands for a SDR receiver but for $149 I think the SDRplay is an awesome piece of hardware that lets me do things with radio I never could before at a price I can stomach.
Finally.... These are not scanners, they are receivers. Big difference. I'm aware that we all know that but sometimes It seems people buy SDRs thinking they will replace a scanner. Yes, I know there are scanning plugins.
edmscan, you said you would rather stick to your scanners because the SDRplay is deaf on VHF and above. I can't speak for yours of course, but I find sensitivity is great on everything from HF to UHF. I have done comparisons to my Kenwood TS-2000 and the SDRplay picks up everything the kenweed can. I have several antennas - HF, VHF, UHF, 800 Mhz, Discone and all of them produce the results they should when coupled with the SDRplay.
A big issue about SDRConsole on VHF/UHF is that the squelch does not work. If you go to a frequency with no signal .. and adjust the squelch. Then you tune to a frequency with activity .. you will get nothing. So what good is it if it does not work.
Unlike HF I don't want to hear 'the noise' unless there is a signal.
And .. it pinning my CPU is another issue. There are a lot of issues with SDRConsole. I am eventually going to try something else .. cause the software so far has been very disappointing.
Flatliner
UK
Are you using SDR-Console 2274? The squelch works fine on mine. If you haven't already, try an uninstall, reboot, then reinstall.
The CPU usage is currently 9% on my i7.
I threw my SDRPlay in the garbage .. done. I will use my scanners.
I don't believe it is the fault of the SDRPlay .. the software out there just stinks. The only hope I had was SDR# but .. cannot get that to run at all.
EDIT .. I pulled it out of the garbage and installed SDR#. It is working now .. and actually quite well. Finally some software that works.
WyoDuner
Las Vegas, NV
It's important that SDR Console v. 2274 be used as it fixes a few SDRplay related issues.
My squelch works fine too.
CPU on my I-5 3.4Ghz is between 5% and 30% depending on sample rate and spectrum span.
One last time I will suggest HDSDR for those that are having issues as it is a little more straight forward but still has a lot of great features hidden just beneath the skin.
HDSDR, SDR-Console and SDR# all have their good and bad points and they all have features that make them stand out from the rest.
Flatliner
UK
I'm really glad that you stuck with it. Which version of SDR# are you using?
Flatliner
UK
If you also want to have another go with SDR-Radio, we'll be happy to help. If you're using v2.3 1423, you'll need to update to the latest version.
I've attached a screenshot of what I have on my screens right now. I currently have three screens dedicated to SDR-Radio, with others doing various decodes etc.
