SDRSharp Audio Recorder volume
causeway74
Hi, I'm using the Audio Recorder plugin with SDR Sharp but I cannot find a way to increase the recording volume. Regardless of the volume settings on the top panel I need to crank up my pc audio to 100% to properly hear the recordings. I can edit later in audacity if necessary but it would be much handier to have it generated properly.
Anyone else use this plugin and have the same experience?
Magpie
Yes, same here. I believe one cannot change the volume. I'm using 1700 and 1732 and believe that the audio in 1732 is slightly louder than in 1700. Htn.
