SDRSharp Tuner AGC
RonnieUSA
Rowan County,KY (Morehead)
Does anyone use it?
The reason I ask is, I was having problems with 1 frequency not sounding very good, signal was up, and down, but after enabling it it's very stable, and sounds great with no drift.
DaveIN
Founders Curmudgen
West Michigan
I use it most of the time. There are occasions when you may need to fine tune a weak signal manually.
Make sure the offset correction (ppm) is correct at the bottom of the Configuration settings.
