I didn’t edit anything. So what do I need to do? Instructions pleaseThat's how it should be unless you edited the serial #'s on the eeproms
One wi showed locked as is works , if the locked tune is receiving a call and another call started outside it's sample rate, the other tuner kicks in
You are good to go, two dongles with the same serial will be fine. Once you start adding more than 3, I believe the need for different serial numbers becomes a consideration.(can't remember exactly, all mine are edited)I didn’t edit anything. So what do I need to do? Instructions please
when im under the channels tab, the drop down on "prefered tuner" only shows 1 dongle. by the looks of things its only seeing 1 dongle. how do i know if its working on two dongles? I have my sds100 monitoring the same system and same tower and sdstrunk im only hearing 50% of what im hearing on the sds100You are good to go, two dongles with the same serial will be fine. Once you start adding more than 3, I believe the need for different serial numbers becomes a consideration.(can't remember exactly, all mine are edited)
under tuners i do see two dongles one shows locked and the other shows unlocked ??While sdr-trunk is running, click the tuner tab , on a busy system both would like show locked, you'll see frequency numbers in both tuners. I don't think you'll see two options in the preferred tuner drop menu as the both have the same info
I'm still missing 50% of traffic compared to my sds100 sitting right next to me. I dont know how to tell if it's using both dongles.
the system im monitoring is Mississippi MSWIN P25P2. the only tower i setup is the North Carrollton tower in Carroll County.What system are you monitoring? The one thats locked is because its locked on the control channel. The other will show unlocked if there is not a voice grant in progress or if the dongle is not set up properly.
Can you post your tuners tab?
- Channels indicates how many channels are being sourced from the tuner. A value of 0 (UNLOCKED) will be displayed when the tuner is not sourcing any channels. A non-zero value, for example: 1 (LOCKED), indicates the number of channels being sourced from the tuner. The LOCKED label indicates that the tuner editor's frequency and sample rate controls are locked and cannot be changed by the user until all of the decoding channels being sourced by the tuner have been stopped.
Post screenshots of the channels page with the system in question and the tuners tab
on the details tab its saying "tuner unavailable"Please use windows snipping tool for the screen shots. What is the reason for the rejected calls in the events tab?
