SDRTrunk How to
musicman476
RR DB Admin
McKinney, Texas
I've been trying to use SDRtrunk lately, but I've been having some trouble. I'm usually pretty adept at figuring programs like this out, but this one has me stumped.
The main issue is how to monitor more than one system. I've entered a local LTR system and it works great. However, when input a new system, most of the frequencies turn red because they're out of band. I've tried disabling, and even deleting frequencies from the first system, but that doesn't work.
Is it not possible "switch off" one system and devote the tuner to another one instead? I'm sure I could add another SDR stick but is that the only way? I see screenshots of the app having several different systems programmed. What am I missing?:confused:
Thanks for your help...I feel rather dumb with this program!
DSheirer
Fulton, NY
If you disable all channels, shut down the application, restart it, and then attempt to enable the second channel, does it start the second channel ok?
Denny
thewraith2008
Which version are you using SDRTrunk 0.2.0 or SDRTrunk 0.3.0-alpha1.
In version SDRTrunk 0.2.0 switch off your first frequency (Green) then switch off 2nd frequency (Red) then switch it back on.
That is click 'Enable' (checked or unchecked) then 'Save'
Cheers
