sdrtrunk pool-1-thread-4] WARN i.g.d.s.t.c.r.ChannelRotationMonitor - Error while checking state
dave3825
Suffolk County NY
Would anyone know what this is and how to fix it? Seems to happen every day and a half resulting in Sdrtrunk having to be shut down and restarted.
20220206 084638.148 [sdrtrunk pool-1-thread-4] INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [548MB/1GB 32%]
20220206 084639.434 [sdrtrunk pool-1-thread-4] WARN i.g.d.s.t.c.r.ChannelRotationMonitor - Error while checking state [840MB/1GB 50%]
java.lang.IllegalStateException: transferPointer is not initialized
at org.usb4java.LibUsb.cancelTransfer(Native Method)
at io.github.dsheirer.source.tuner.usb.USBTransferProcessor.stop(USBTransferProcessor.java:172)
at io.github.dsheirer.source.tuner.usb.USBTransferProcessor.removeListener(USBTransferProcessor.java:383)
at io.github.dsheirer.source.tuner.usb.USBTunerController.removeBufferListener(USBTunerController.java:69)
at io.github.dsheirer.dsp.filter.channelizer.PolyphaseChannelManager.stopChannelSource(PolyphaseChannelManager.java:268)
at io.github.dsheirer.dsp.filter.channelizer.PolyphaseChannelManager$ChannelSourceEventListener.receive(PolyphaseChannelManager.java:530)
at io.github.dsheirer.dsp.filter.channelizer.PolyphaseChannelManager$ChannelSourceEventListener.receive(PolyphaseChannelManager.java:509)
at io.github.dsheirer.source.tuner.channel.TunerChannelSource.broadcastProducerSourceEvent(TunerChannelSource.java:214)
at io.github.dsheirer.source.tuner.channel.TunerChannelSource.stop(TunerChannelSource.java:137)
at io.github.dsheirer.source.tuner.channel.MultiFrequencyTunerChannelSource.rotate(MultiFrequencyTunerChannelSource.java:95)
at io.github.dsheirer.source.tuner.channel.MultiFrequencyTunerChannelSource.process(MultiFrequencyTunerChannelSource.java:351)
at io.github.dsheirer.source.SourceEventListenerToProcessorAdapter.receive(SourceEventListenerToProcessorAdapter.java:51)
at io.github.dsheirer.source.SourceEventListenerToProcessorAdapter.receive(SourceEventListenerToProcessorAdapter.java:25)
at io.github.dsheirer.sample.Broadcaster.broadcast(Broadcaster.java:152)
at io.github.dsheirer.sample.Broadcaster.receive(Broadcaster.java:59)
at io.github.dsheirer.source.tuner.channel.rotation.ChannelRotationMonitor.checkState(ChannelRotationMonitor.java:148)
at io.github.dsheirer.source.tuner.channel.rotation.ChannelRotationMonitor.lambda$start$0(ChannelRotationMonitor.java:179)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
20220206 101648.113 [sdrtrunk pool-1-thread-4] WARN i.g.d.s.t.c.r.ChannelRotationMonitor - Error while checking state [947MB/1GB 56%]
20220206 101659.884 [sdrtrunk pool-1-thread-7] WARN i.g.d.s.t.c.r.ChannelRotationMonitor - Error while checking state [387MB/1GB 23%]
20220206 101702.760 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Application shutdown started ... [390MB/1GB 23%]
20220206 101702.822 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping channels ... [390MB/1GB 23%]
20220206 101702.824 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping spectral display ... [390MB/1GB 23%]
20220206 101702.855 [AWT-EventQueue-0] INFO i.g.d.s.tuner.TunerManager - Releasing [1] tuner(s) ... [390MB/1GB 23%]
20220206 101702.866 [AWT-EventQueue-0] INFO i.g.d.s.t.a.AirspyTunerController - Releasing Airspy Tuner - 04A464C8-342F810B [390MB/1GB 23%]
20220206 101702.873 [AWT-EventQueue-0] INFO i.g.d.s.tuner.TunerManager - Shutting down LibUsb timeout processor ... [390MB/1GB 23%]
20220206 101702.873 [AWT-EventQueue-0] INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [390MB/1GB 23%]
20220206 101703.875 [AWT-EventQueue-0] INFO i.g.d.s.tuner.TunerManager - Shutting down LibUsb ... [390MB/1GB 23%]
20220206 101703.886 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Shutdown complete. [390MB/1GB 23%]
20220206 101703.886 [AWT-EventQueue-0] INFO i.g.d.log.ApplicationLog - Stopping application logging [390MB/1GB 23%]
And this,
20220205 233325.773 [sdrtrunk pool-1-thread-3] ERROR i.g.d.d.f.c.o.ChannelOutputProcessor - Error while processing polyphase channel samples [890MB/1GB 53%]
java.lang.NullPointerException: Cannot invoke "io.github.dsheirer.sample.Listener.receive(Object)" because "this.mListener" is null
at io.github.dsheirer.sample.buffer.ReusableComplexBufferAssembler.flush(ReusableComplexBufferAssembler.java:157)
at io.github.dsheirer.sample.buffer.ReusableComplexBufferAssembler.receive(ReusableComplexBufferAssembler.java:131)
at io.github.dsheirer.sample.buffer.ReusableComplexBufferAssembler.receive(ReusableComplexBufferAssembler.java:143)
at io.github.dsheirer.dsp.filter.channelizer.output.OneChannelOutputProcessor.process(OneChannelOutputProcessor.java:97)
at io.github.dsheirer.dsp.filter.channelizer.output.ChannelOutputProcessor.processChannelResults(ChannelOutputProcessor.java:124)
at io.github.dsheirer.dsp.filter.channelizer.PolyphaseChannelSource.processSamples(PolyphaseChannelSource.java:248)
at io.github.dsheirer.source.tuner.channel.TunerChannelSource$ScheduledIntervalProcessor.run(TunerChannelSource.java:315)
maus92
OCMD
Can you give us some info about your hardware setup, and has the program ever worked for you?
dave3825
Suffolk County NY
Program has been running without these errors for past year on Win 10 64 bit with Intel i7 4790 @3.60Ghz with 8gb ram with Airspy mini. I would fire it up and that was it. 4 5 10 days later it would still be running. Now it seems after a day or 2 it gets hung up.
maus92
OCMD
Sounds suspiciously like a memory issue. Any other hardware changes recently? You can try the basics like changing usb ports, reseating cables, changing cables, etc. You could reinstall the program. Check if Java is up to date. Do you have another Airspy or set of RTL SDRs?
dave3825
Suffolk County NY
It does it with both my Airspy and Nooelec's. I have not done anything with this pc at all as far as hardware or software changes. This started about 2 weeks ago.
maus92
OCMD
I would still re-seat the cables / sdr as usb connectors can be finicky. Changing ports and cables is basically free, and would eliminate that as a cause. I'd look at Java memory allocation as that is a known issue with the program - also an easy fix. There is a solution for this somewhere in these forums - I've never had to do it.
dave3825
Suffolk County NY
I increased the java mem a long time ago when I was getting "java.lang.OutOfMemoryError: Java heap space " errors but I am only getting the errors listed in the first post now.
I will reseat the dongles when I get home today and see if it cure these issues.
dave3825
Suffolk County NY
So I reseated all my dongles and that did not seem to cure this issue,,,
13:40:38.161 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [192MB/494MB 39%]
14:47:18.911 WARN i.g.d.s.t.c.r.ChannelRotationMonitor - Error while checking state [431MB/494MB 87%]
maus92
OCMD
Weird. My installation runs 24/7 on a Linux box using an Airspy Mini without issue so I cannot reproduce the error. I do install Linux updates every few days, so the program gets restarted roughly once a week or so.
dave3825
Suffolk County NY
I wonder if widows did some kind of update. I used to run this without any problems for up to two weeks at a time .
I have a Pi3B+ somewhere. I have to see if it will run on that.
dave3825
Suffolk County NY
Did a full shut down and restarted 24 hours ago. Wondering if something is going on with the usb. Just opened the program and control channel status was displaying " idle ", Went into the dos screen and it was cycling ,
18:18:08.126 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [375MB/482MB 77%]
07:39:46.620 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [368MB/482MB 76%]
07:39:48.093 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [333MB/482MB 69%]
07:39:49.129 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [340MB/482MB 70%]
07:39:50.201 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [278MB/482MB 57%]
07:39:51.218 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [278MB/482MB 57%]
Now its locked on the control channel again. Not seeing the transferPointer is not initialized error just yet but its still early. Getting 100 percent on control channels reception wise and ppm is dead on. Will see what its saying later on..
maus92
OCMD
What system is this? Is it a Harris system where the control channels rotate?
dave3825
Suffolk County NY
Im not sure if its Harris or Moto. This is the system Suffolk County (Project 25) Trunking System, Suffolk County, New York - Scanner Frequencies
I am sure if @GTR8000 or @w2lie swing by they would know. I know the cc does alternate.
Is "starting and stopping usb master processor" the cycling of control channels? If so, I do not remember them changing as frequent as shown below. Maybe they do. I am going to try to watch the active cc during the day.
This is from when I rebooted up until now.
12:34:47.671 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [31MB/50MB 63%]
12:34:48.701 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [190MB/272MB 69%]
12:34:49.719 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [191MB/272MB 70%]
13:45:13.376 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [218MB/474MB 46%]
13:45:14.385 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [218MB/474MB 46%]
13:58:49.752 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [292MB/474MB 61%]
13:58:50.767 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [292MB/474MB 61%]
13:58:51.850 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [277MB/474MB 58%]
13:58:52.867 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [277MB/474MB 58%]
15:50:26.125 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [217MB/474MB 45%]
15:50:27.150 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [218MB/474MB 46%]
15:50:28.227 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [309MB/474MB 65%]
15:50:29.242 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [309MB/474MB 65%]
15:50:30.327 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [403MB/474MB 85%]
15:50:31.342 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [403MB/474MB 85%]
17:32:36.550 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [385MB/474MB 81%]
17:32:37.569 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [385MB/474MB 81%]
17:32:38.654 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [325MB/474MB 68%]
17:32:39.675 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [325MB/474MB 68%]
17:32:40.752 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [357MB/474MB 75%]
17:32:41.780 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [357MB/474MB 75%]
09:03:28.677 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [517MB/597MB 86%]
09:03:29.689 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [517MB/597MB 86%]
maus92
OCMD
It's a Moto system. They "normally" do not rotate control channels. What site are you monitoring? I've never seen the behavior that your logs are showing which is why I suspect an issue with the USB device drivers or hardware related to USB. Have you tried nuking the installation then reinstalling SDRTrunk / rebuilding the Java libraries?
dave3825
Suffolk County NY
Its on win 10 did the install for download, unzip, and run Windows sdr-trunk.bat. Going to back up my playlists and redownload and try again. Before I do that, I think I am going to remote in to this pc from another pc and wipe and reinstall all the usb drivers for usbhubs and root usb stuff.
maus92
OCMD
This is my logged startup. I have 2 control channels and 3 traffic channels enabled. Not sure if each traffic channel is considered a thread wrt the USB Master Processor, but 3 threads are running: 1, 3 and 4.
Code:
20220212 140743.478 [main] INFO  i.g.d.log.ApplicationLog - SDRTrunk Version  : 0.5.0-alpha6  [13MB/250MB 5%]
20220212 140743.478 [main] INFO  i.g.d.log.ApplicationLog - Gradle Version    : Gradle 6.3  [13MB/250MB 5%]
20220212 140743.479 [main] INFO  i.g.d.log.ApplicationLog - Build Timestamp   : 2020-10-26T04:29:57.816-0400  [13MB/250MB 5%]
20220212 140743.479 [main] INFO  i.g.d.log.ApplicationLog - Build-JDK         : 15 (BellSoft 15+36  [13MB/250MB 5%]
20220212 140743.479 [main] INFO  i.g.d.log.ApplicationLog - Build OS          : Linux (amd64 4.4.0-193-generic  [13MB/250MB 5%]
20220212 140743.479 [main] INFO  i.g.d.log.ApplicationLog -   [13MB/250MB 5%]
20220212 140743.479 [main] INFO  i.g.d.log.ApplicationLog - *******************************************************************  [13MB/250MB 5%]
20220212 140743.479 [main] INFO  i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application ***  [13MB/250MB 5%]
20220212 140743.479 [main] INFO  i.g.d.log.ApplicationLog - ****  website: https://github.com/dsheirer/sdrtrunk             ***  [13MB/250MB 5%]
20220212 140743.480 [main] INFO  i.g.d.log.ApplicationLog - *******************************************************************  [13MB/250MB 5%]
20220212 140743.480 [main] INFO  i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%]  [13MB/250MB 5%]
20220212 140743.480 [main] INFO  i.g.d.log.ApplicationLog - Host OS Name:          Linux  [13MB/250MB 5%]
20220212 140743.480 [main] INFO  i.g.d.log.ApplicationLog - Host OS Arch:          amd64  [13MB/250MB 5%]
20220212 140743.480 [main] INFO  i.g.d.log.ApplicationLog - Host OS Version:       5.4.0-99-generic  [13MB/250MB 5%]
20220212 140743.481 [main] INFO  i.g.d.log.ApplicationLog - Host CPU Cores:        4  [13MB/250MB 5%]
20220212 140743.481 [main] INFO  i.g.d.log.ApplicationLog - Host Max Java Memory:  3 GB  [13MB/250MB 5%]
20220212 140743.481 [main] INFO  i.g.d.log.ApplicationLog - Storage Directories:  [13MB/250MB 5%]
20220212 140743.481 [main] INFO  i.g.d.log.ApplicationLog -  Application Root: /home/charley/SDRTrunk  [13MB/250MB 5%]
20220212 140743.481 [main] INFO  i.g.d.log.ApplicationLog -  Application Log:  /home/charley/SDRTrunk/logs  [13MB/250MB 5%]
20220212 140743.481 [main] INFO  i.g.d.log.ApplicationLog -  Event Log:        /home/charley/SDRTrunk/event_logs  [13MB/250MB 5%]
20220212 140743.482 [main] INFO  i.g.d.log.ApplicationLog -  Playlist:         /home/charley/SDRTrunk/playlist  [13MB/250MB 5%]
20220212 140743.482 [main] INFO  i.g.d.log.ApplicationLog -  Recordings:       /home/charley/SDRTrunk/recordings  [13MB/250MB 5%]
20220212 140743.570 [main] INFO  i.g.dsheirer.util.ThreadPool - Application thread pool created with [4] threads  [8MB/250MB 3%]
20220212 140743.570 [main] INFO  i.github.dsheirer.gui.SDRTrunk - Home path: /home/charley/SDRTrunk  [8MB/250MB 3%]
20220212 140743.571 [main] INFO  i.g.d.p.SystemProperties - SystemProperties - loaded [/home/charley/SDRTrunk/SDRTrunk.properties]  [8MB/250MB 3%]
20220212 140743.571 [main] INFO  i.g.d.p.SystemProperties - SystemProperties - application properties loaded [/home/charley/SDRTrunk/SDRTrunk.properties]  [8MB/250MB 3%]
20220212 140743.580 [main] INFO  i.g.d.settings.SettingsManager - SettingsManager - loading settings file [/home/charley/SDRTrunk/settings/settings.xml]  [9MB/250MB 3%]
20220212 140743.770 [main] INFO  i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations  [20MB/34MB 61%]
20220212 140743.779 [main] INFO  i.g.d.s.tuner.TunerManager - LibUSB API Version: 16777478  [21MB/34MB 63%]
20220212 140743.780 [main] INFO  i.g.d.s.tuner.TunerManager - LibUSB Version: 1.0.22.11312  [21MB/34MB 63%]
20220212 140743.780 [main] INFO  i.g.d.s.tuner.TunerManager - discovered [7] attached USB devices  [21MB/34MB 63%]
20220212 140743.784 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [2] Device [1D6B:0003] Hub Device  [21MB/34MB 63%]
20220212 140743.784 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [1] Device [8087:0A2B] Wireless Controller Device  [21MB/34MB 63%]
20220212 140743.824 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [1] Device [1D50:60A1] LOADED: Airspy 62CC68FF-211C2017 Max Rate:320000000 bps  [23MB/34MB 68%]
20220212 140743.825 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [1] Device [258A:0036] Unknown Device - Class 0  [23MB/34MB 68%]
20220212 140743.825 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [1] Device [046D:C33F] Unknown Device - Class 0  [23MB/34MB 68%]
20220212 140743.825 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [1] Device [0409:005A] Hub Device  [23MB/34MB 68%]
20220212 140743.825 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [1] Device [1D6B:0002] Hub Device  [23MB/34MB 68%]
20220212 140743.826 [main] INFO  i.g.d.s.tuner.TunerManager - -------------------------------------------------------------  [23MB/34MB 68%]
20220212 140743.826 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus - Potential Maximum Data Rates  [23MB/34MB 68%]
20220212 140743.829 [main] INFO  i.g.d.s.tuner.TunerManager - USB Bus [1] Rate [320000000] bits per second  [23MB/34MB 69%]
20220212 140744.613 [main] INFO  i.g.d.playlist.PlaylistManager - Loading playlist [/home/charley/SDRTrunk/playlist/default.xml]  [18MB/38MB 47%]
20220212 140744.800 [main] INFO  i.github.dsheirer.gui.SDRTrunk - starting main application gui  [17MB/38MB 47%]
20220212 140807.592 [sdrtrunk pool-1-thread-1] INFO  i.g.d.a.c.mbe.JmbeAudioModule - Loading JMBE library from [/home/charley/SDRTrunk/jmbe/jmbe-1.0.7b.jar]  [103MB/174MB 59%]
20220212 140807.601 [sdrtrunk pool-1-thread-1] INFO  i.g.d.a.c.mbe.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.6  [103MB/174MB 59%]
20220212 140807.602 [sdrtrunk pool-1-thread-1] INFO  i.g.d.a.c.mbe.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available  [103MB/174MB 59%]
20220212 140807.617 [sdrtrunk pool-1-thread-1] INFO  i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [6000000.0] providing [240] channels at [25000.0] Hz each  [104MB/174MB 60%]
20220212 140807.643 [sdrtrunk pool-1-thread-1] INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [113MB/174MB 65%]
20220212 140808.019 [sdrtrunk pool-1-thread-3] INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [161MB/210MB 77%]
20220212 140809.036 [sdrtrunk pool-1-thread-3] INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [160MB/274MB 58%]
20220212 140809.628 [sdrtrunk pool-1-thread-4] INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [210MB/432MB 48%]
20220212 140810.635 [sdrtrunk pool-1-thread-4] INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [212MB/432MB 49%]
20220212 140810.917 [sdrtrunk pool-1-thread-3] INFO  i.g.d.a.c.mbe.AmbeAudioModule - AMBE CODEC successfully loaded - P25-2/DMR/NXDN audio will be available  [239MB/432MB 55%]
dave3825
Suffolk County NY
This is mine. Its been running a while now and there is many more start stop of usb but what I entered exceeded 15000 characters.
Code:
20:29:26.270 INFO  i.g.d.icon.IconModel - loading icons file [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml]  [11MB/124MB 9%]
20:29:26.275 INFO  i.g.d.icon.IconModel - Icons file not found at [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml]  [11MB/124MB 9%]
20:29:26.973 INFO  i.g.d.log.ApplicationLog - Application Log File: C:\Users\Preferred Customer\SDRTrunk\logs\sdrtrunk_app.log  [19MB/124MB 15%]
20:29:27.006 INFO  i.g.d.log.ApplicationLog - SDRTrunk Version  : 0.5.0-alpha6  [22MB/124MB 18%]
20:29:27.006 INFO  i.g.d.log.ApplicationLog - Gradle Version    : Gradle 6.3  [22MB/124MB 18%]
20:29:27.007 INFO  i.g.d.log.ApplicationLog - Build Timestamp   : 2020-10-26T04:29:57.816-0400  [22MB/124MB 18%]
20:29:27.007 INFO  i.g.d.log.ApplicationLog - Build-JDK         : 15 (BellSoft 15+36  [22MB/124MB 18%]
20:29:27.007 INFO  i.g.d.log.ApplicationLog - Build OS          : Linux (amd64 4.4.0-193-generic  [22MB/124MB 18%]
20:29:27.007 INFO  i.g.d.log.ApplicationLog -   [22MB/124MB 18%]
20:29:27.007 INFO  i.g.d.log.ApplicationLog - *******************************************************************  [22MB/124MB 18%]
20:29:27.008 INFO  i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application ***  [22MB/124MB 18%]
20:29:27.008 INFO  i.g.d.log.ApplicationLog - ****  website: https://github.com/dsheirer/sdrtrunk             ***  [22MB/124MB 18%]
20:29:27.008 INFO  i.g.d.log.ApplicationLog - *******************************************************************  [22MB/124MB 18%]
20:29:27.008 INFO  i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%]  [22MB/124MB 18%]
20:29:27.009 INFO  i.g.d.log.ApplicationLog - Host OS Name:          Windows 10  [22MB/124MB 18%]
20:29:27.009 INFO  i.g.d.log.ApplicationLog - Host OS Arch:          amd64  [22MB/124MB 18%]
20:29:27.009 INFO  i.g.d.log.ApplicationLog - Host OS Version:       10.0  [22MB/124MB 18%]
20:29:27.009 INFO  i.g.d.log.ApplicationLog - Host CPU Cores:        8  [22MB/124MB 18%]
20:29:27.010 INFO  i.g.d.log.ApplicationLog - Host Max Java Memory:  2 GB  [23MB/124MB 18%]
20:29:27.010 INFO  i.g.d.log.ApplicationLog - Storage Directories:  [23MB/124MB 18%]
20:29:27.010 INFO  i.g.d.log.ApplicationLog -  Application Root: C:\Users\Preferred Customer\SDRTrunk  [23MB/124MB 18%]
20:29:27.010 INFO  i.g.d.log.ApplicationLog -  Application Log:  C:\Users\Preferred Customer\SDRTrunk\logs  [23MB/124MB 18%]
20:29:27.012 INFO  i.g.d.log.ApplicationLog -  Event Log:        C:\Users\Preferred Customer\SDRTrunk\event_logs  [23MB/124MB 18%]
20:29:27.012 INFO  i.g.d.log.ApplicationLog -  Playlist:         C:\Users\Preferred Customer\SDRTrunk\playlist  [23MB/124MB 18%]
20:29:27.013 INFO  i.g.d.log.ApplicationLog -  Recordings:       C:\Users\Preferred Customer\SDRTrunk\recordings  [23MB/124MB 18%]
20:29:27.021 INFO  i.g.d.util.ThreadPool - Application thread pool created with [8] threads  [6MB/124MB 4%]
20:29:27.021 INFO  i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\Preferred Customer\SDRTrunk  [6MB/124MB 4%]
20:29:27.027 INFO  i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties]  [6MB/124MB 4%]
20:29:27.028 INFO  i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties]  [6MB/124MB 4%]
20:29:27.045 INFO  i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\Preferred Customer\SDRTrunk\settings\settings.xml]  [6MB/124MB 5%]
20:29:27.258 INFO  i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations  [10MB/27MB 39%]
20:29:27.378 INFO  i.g.d.s.t.TunerManager - LibUSB API Version: 16777478  [12MB/27MB 44%]
20:29:27.379 INFO  i.g.d.s.t.TunerManager - LibUSB Version: 1.0.22.11312  [12MB/27MB 44%]
20:29:27.534 INFO  i.g.d.s.t.TunerManager - discovered [10] attached USB devices  [12MB/27MB 44%]
20:29:27.548 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [8087:8008] Hub Device  [12MB/27MB 44%]
20:29:27.549 INFO  i.g.d.s.t.TunerManager - USB Bus [3] Device [8087:8000] Hub Device  [12MB/27MB 44%]
20:29:27.550 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [046D:C52F] Unknown Device - Class 0  [12MB/27MB 44%]
20:29:27.551 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [413C:2111] Unknown Device - Class 0  [12MB/27MB 44%]
20:29:27.559 ERROR i.g.d.s.t.TunerManager - couldn't determine RTL2832 tuner type  [12MB/27MB 44%]
io.github.dsheirer.source.SourceException: couldn't open device - check permissions Linux: udev.rule? , or Windows: reinstall Zadig? [LIBUSB_ERROR_ACCESS]
        at io.github.dsheirer.source.tuner.rtl.RTL2832TunerController.identifyTunerType(RTL2832TunerController.java:346)
        at io.github.dsheirer.source.tuner.TunerManager.initRTL2832Tuner(TunerManager.java:476)
        at io.github.dsheirer.source.tuner.TunerManager.initTuner(TunerManager.java:333)
        at io.github.dsheirer.source.tuner.TunerManager.initTuners(TunerManager.java:148)
        at io.github.dsheirer.source.tuner.TunerManager.<init>(TunerManager.java:79)
        at io.github.dsheirer.source.SourceManager.<init>(SourceManager.java:46)
        at io.github.dsheirer.gui.SDRTrunk.<init>(SDRTrunk.java:167)
        at io.github.dsheirer.gui.SDRTrunk.main(SDRTrunk.java:624)
20:29:27.573 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [0BDA:2838] Unknown Device - Class 0  [12MB/27MB 46%]
20:29:27.574 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [8086:8C31] Hub Device  [12MB/27MB 46%]
20:29:27.574 ERROR i.g.d.s.t.TunerManager - couldn't determine RTL2832 tuner type  [12MB/27MB 46%]
20:29:27.575 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [0BDA:2838] Unknown Device - Class 0  [12MB/27MB 46%]
20:29:27.577 INFO  i.g.d.s.t.TunerManager - USB Bus [3] Device [8086:8C26] Hub Device  [12MB/27MB 46%]
20:29:27.621 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [1D50:60A1] LOADED: Airspy 04A464C8-342F810B Max Rate:320000000 bps  [15MB/27MB 55%]
20:29:27.622 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [8086:8C2D] Hub Device  [15MB/27MB 55%]
20:29:27.622 INFO  i.g.d.s.t.TunerManager - -------------------------------------------------------------  [15MB/27MB 55%]
20:29:27.623 INFO  i.g.d.s.t.TunerManager - USB Bus - Potential Maximum Data Rates  [15MB/27MB 55%]
20:29:27.628 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Rate [320000000] bits per second  [15MB/27MB 55%]
20:29:29.957 INFO  i.g.d.p.PlaylistManager - Loading playlist [C:\Users\Preferred Customer\SDRTrunk\playlist\default.xml]  [14MB/30MB 47%]
20:29:30.175 INFO  i.g.dsheirer.gui.SDRTrunk - starting main application gui  [17MB/30MB 57%]
20:29:32.662 INFO  i.g.d.c.c.ChannelAutoStartFrame - Starting [1] channels now - user invoked  [29MB/50MB 58%]
20:29:32.743 INFO  i.g.d.a.c.m.JmbeAudioModule - Loading JMBE library from [C:\Users\Preferred Customer\SDRTrunk\jmbe\jmbe-1.0.7b.jar]  [32MB/50MB 65%]
20:29:32.750 INFO  i.g.d.a.c.m.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.6  [32MB/50MB 65%]
20:29:32.750 INFO  i.g.d.a.c.m.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available  [32MB/50MB 65%]
20:29:32.772 INFO  i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [6000000.0] providing [240] channels at [25000.0] Hz each  [33MB/50MB 67%]
20:29:32.802 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [31MB/50MB 63%]
20:29:33.834 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [202MB/295MB 68%]
20:29:34.855 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [203MB/295MB 69%]
20:42:10.885 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [192MB/295MB 65%]
20:42:11.894 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [192MB/295MB 65%]
20:42:12.984 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [227MB/295MB 77%]
20:42:14.002 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [228MB/295MB 77%]
20:42:15.085 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [258MB/295MB 87%]
20:42:16.094 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [258MB/295MB 87%]
20:49:58.660 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [278MB/354MB 78%]
20:49:59.666 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [278MB/354MB 78%]
20:50:00.759 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [215MB/354MB 61%]
20:50:01.772 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [216MB/354MB 61%]
20:50:02.859 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [281MB/354MB 79%]
20:50:03.877 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [281MB/354MB 79%]
22:00:18.598 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [185MB/422MB 44%]
22:00:19.615 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [192MB/422MB 45%]
22:00:20.709 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [311MB/422MB 73%]
22:00:21.722 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [311MB/422MB 73%]
22:16:41.410 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [153MB/427MB 35%]
22:16:42.426 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [153MB/427MB 35%]
22:16:43.508 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [222MB/427MB 52%]
22:16:44.533 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [222MB/427MB 52%]
22:51:16.734 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [114MB/430MB 26%]
22:51:17.740 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [114MB/430MB 26%]
23:38:06.534 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [398MB/459MB 86%]
23:38:07.539 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [403MB/459MB 87%]
23:38:08.632 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [352MB/459MB 76%]
23:38:09.649 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [352MB/459MB 76%]
00:21:45.234 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [188MB/480MB 39%]
00:21:46.255 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [189MB/480MB 39%]
00:24:38.484 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [152MB/480MB 31%]
00:24:39.511 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [153MB/480MB 31%]
00:24:40.583 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [399MB/480MB 83%]
00:24:41.612 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [399MB/480MB 83%]
00:41:11.259 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [103MB/480MB 21%]
00:41:12.269 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [104MB/480MB 21%]
00:41:13.359 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [339MB/480MB 70%]
00:41:14.370 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [340MB/480MB 70%]
01:09:48.536 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [395MB/480MB 82%]
01:09:49.548 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [396MB/480MB 82%]
01:24:49.433 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [399MB/484MB 82%]
01:24:50.443 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [399MB/484MB 82%]
01:24:51.534 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [226MB/484MB 46%]
01:24:52.548 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [226MB/484MB 46%]
01:24:53.634 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [267MB/484MB 55%]
01:24:54.644 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [268MB/484MB 55%]
01:24:55.736 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [305MB/484MB 63%]
01:24:56.744 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [305MB/484MB 63%]
maus92
OCMD
How did you install your SDR drivers under Zadig? Seems to be an issue according to the log. Can ou post a screenshot of Device Manager showing the SDR devices?
dave3825
Suffolk County NY
Is that the issue you see? If so, it does that when and if other software ( Unitrunker - DSDPlus ) is using the Nooelec dongles. If I start Sdrtrunk with all dongles available, that does not come up. I have been only using an Airspy mini with Sdrtrunk for the last few weeks.
I was also up between 2 and 3 am, and cc was 852.425 and as of now @ 9 15 am , its still the same cc.
This is from midnight till now. No entries since 4 am and it is still running good without errors. but it did start/stop a bit.
Code:
00:53:53.820 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [586MB/779MB 75%]
02:47:17.334 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [459MB/797MB 57%]
02:47:18.344 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [460MB/797MB 57%]
02:47:19.433 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [609MB/797MB 76%]
02:47:20.457 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [609MB/797MB 76%]
03:03:17.034 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [501MB/797MB 62%]
03:03:18.048 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [502MB/797MB 63%]
03:03:19.134 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [661MB/797MB 83%]
03:03:20.153 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [661MB/797MB 83%]
03:03:21.234 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [343MB/797MB 43%]
03:03:22.244 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [343MB/797MB 43%]
03:56:17.484 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [368MB/805MB 45%]
03:56:18.509 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [368MB/805MB 45%]
03:56:19.586 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [500MB/805MB 62%]
03:56:20.616 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [501MB/805MB 62%]
03:56:21.685 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [611MB/805MB 75%]
03:56:22.696 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [611MB/805MB 75%]
03:56:23.785 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [263MB/805MB 32%]
03:56:24.794 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [265MB/805MB 32%]
This is dev manager.
I also check power settings and sleep is set to never.
maus92
OCMD
That and 2 lines in the log that mention "reinstall Zadig."
Are the Nooelec SDRs plugged into USB ports when running SDRTrunk? If so, I would unplug them and restart SDRTrunk and compare the log and see how the program runs. I'm also going to run my Windows installation of SDRTrunk and compare logs.
Note that I run Unitrunker 2.1 with both Nooelec and Airspy SDRs and I do not see any errors - you say that you do see similar SDR errors when running those programs. Can you post those errors / warnings?
