sdrtrunk-vce - web interface, analytics, optimizations - Testers Wanted!
BM82557
Berkeley Co WV
  • RadioReference talkgroups marked fully encrypted are imported with playback, recording, and external streaming disabled.
Can these settings be changed by the user if the talkgroup config is changed by the system admin or the RR marking is incorrect?
dave3825
Suffolk County NY
@tylerwatt12
Trying to go from the previous nightly ( 2026-08-03T ) to the latest nightly.
When I choose "Choose Install" and direct it to the data folder in the nightly I use, I get this.
When I choose Migrate Existing, I get the same.
If I choose use found xml, it loads up with no systems in playlist editor.
If I copy nightly data folder that I using and paste it into the newest nightly, I get
If I hit migrate and start,
tylerwatt12
Cleveland
Yes, they're just imported that way, nothing is preventing you from changing that after import.
The RR importer also compares the RR DB against the selected Alias List. There is an "Import Status" column with values "Different", "Identical", and "Not Present"
You can sort by column by clicking on it
You can also shift click ranges, and ctrl click individual records if you just want to import/update specific ones.
@tylerwatt12
The last nightly was left in a botched state. I'm fixing it. Could you PM me your XML file so I have some more samples?
dave3825
Suffolk County NY
I imported a backup xml from Denny Sdrtrunk into either nightly or alpha at some point. Been running the 8 3 2026 nightly and made a bunch of changes to my play lists in that. That is what I am looking to preserve and use.
What xml are you looking for? I don't have one in either nightly after it did what ever it did?
iiscottybotty
When a call finishes it lingers in the status column and doesn’t clear until another call comes in (nothing in queue). Any fix or settings for this bug?
Scott
dave3825
Suffolk County NY
Its not a bug.
I think that's a feature that can be turned off.
Correct.
Uncheck first box. Hit ok in bottom right (not in my pic) and as calls come in, they rows will clear out. If there was an entry on a slow freq, it may take a while.
Otherwise, after you hit ok, restart the program and it will start with no stored entries.
BM82557
Berkeley Co WV
Alpha 10 -- Infrequent but does occur - a "known" talk group that I don't have configured to record does record one transmission
iiscottybotty
downloaded fresh copy of alpha and setup a new dmr trunk and unticked retain last call and its still doing it. must be a bug in the newer versions
uzbek197
Спасибо за проделанную большую работу! Программа превосходная все понятно и очень удобно, но есть просьба:
Можно ли добавить языковой переключатель конкретно Русский,
. добавить приемник Pluto++(Z7010-AD9361)
И такой вопрос что такое Voice Decryption Module и как им пользоваться
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
You should consider translating to English
Thank you for the tremendous amount of work you’ve put into this! The program is excellent—everything is clear and very user-friendly—but I have a few requests:
Could you add a language switcher (specifically for Russian)?
Could you add support for the Pluto++ (Z7010-AD9361) receiver?
Also, I have a question: what is the "Voice Decryption Module," and how do I use it?
tylerwatt12
Cleveland
latest nightly is out now. Here’s a summarized list of changes.
  • Safer upgrades for recognized Alpha 8-and-newer databases, including staged migration, backups, validation, and post-setup SQLite database import.
  • Rewritten multi-site call handling that combines duplicate copies, selects the best audio, and prevents duplicate playback, recording, streaming, and statistics.
  • A new site-specific Broadcastify Calls provider, allowing several monitored sites to share one Alias List while routing calls to the correct feed.
  • Manual P25 bandplan overrides with entry page on web interface
  • A new option to show only active trunked channels on the Live page. (Like classic sdrtrunk)
  • Saved column widths, order, and visibility for tables throughout the website.
  • Browser-tab titles that show the current alias or TGID and queued-call count.
  • A simpler browser playback system with one queue that clears when stopped.
  • Per-user settings for page titles, Live presentation, Scanner behavior, selected Scan Lists, tuner display, health alerts, and other personal preferences.
  • Browser-based Alias administration with improved Discover and Activity views, conflict information, and bulk Scan List membership controls.
  • Automatic admin sign in to the web interface from the Java application’s Web button.
  • More reliable navigation for configured talkgroups, sites, and conventional channels that have no recent calls.
  • Improved Receiver Health with accurate status wording, personal alert switches, collapsed sections, and paginated resolved incidents.
  • Separate Alpha and Nightly update channels so each release line can maintain its own feature set.
  • Cleaner settings pages, tables, dialogs, Columns menus, filters, metric cards, and dark-mode styling.
  • Millisecond precision in completed-call recording filenames to better avoid collisions.
  • Receiver scheduling changes intended to reduce IQ-buffer pressure and real-time logging overhead.
There is also Alpha 11 out. Mostly bug fixes, also brought over a few features from nightly
