I have been using SDRTrunk with Trunking recorder for a while now to monitor/record my local P25 system with a ton of success (outside crashes in SDRTrunk due to it running on an underpowered computer). I highly recommend this setup for anyone who prefers archival/recall of calls versus live streaming. I tend not to have the scanner running, but like to be able to hop on and see recent calls when there is activity in my area.
I am now looking at Rdio-Scanner and loving what the interface has to offer, but It seems that I cannot use Trunking Recorder at the same time as Radio. Does anyone have experience using both?
Setup is currently SDRTrunk for Monitor/Recording files.
Ingesting to Trunking Recorder and deleting original files. This allows the Trunking Recorder web interface to do most of what I am looking for.
When I set up Rdio I set it to reference the Trunking Recorders save location and using DIRWatch, initially with Delete After enabled. But this deletes the original files, that I still want available to Trunking Recorder. I just switched off the Delete After, but it seems to be a setting people recommend keeping on.
It also started playing the files back from when I initially set the system up, rather than being the most recent files.
Is there a way to use both services at the same time?
Alternatively I could move to Rdio and remove trunking recorder from the mix as it seems that it can do the archival recall as well.
Looking to hear any thoughts the community might have.
Thanks!
Edit, turned off Delete After and it seems like I can run both services at the same time, still would love to hear about experiences doing so if anyone has any.
Thanks!
