Thanks for the suggestion. I forgot to mention that this antenna will primarily be used for when I'm outside of my home (fire scene, accident, etc.) I purchased a Diamond HC-200B for the purpose of cutting it down.
HC200B: 350 to 520MHz with Cutting Chart
Length:0.19m / Weight:45g
Gain:2.15dBi / Max.power rating:10W / Impedance:50ohms
VSWR:Less than 1.5:1 / Connector:BNCP / Type: 1/4λ,120/150/300/450/800/900MHz receiving only
I have an AEA 140-525 Analyst, so I guess that I should get off my butt and start hacking. At home, I have external antennas.
For general UHF/T, I normally use the RH77CA. If you want to focus specifically on 500-512MHz, I'd pull the cap off the tip, trim as needed, then glue the cap back on.
I use BNC antennas exclusively, and have adapters semi-permanently attached to all my scanners with SMA connectors. It reduces the number of antennas I need to keep in stock, and exponentially reduces wear on the SMA connectors, which are not designed to handle as many connection cycles as BNC.
