SDS100/SDS200: SDS-100 flush mount BNC Adapter
fdnyfish
Barnesville, PA
Can someone point me to a flush mount bnc adaptor for the sds-100. I’m not a fan of the one that came with the scanner.
thanks
kruser
West St Louis County, MO
Just bought one, I hope it’s the flat one and not the one Uniden gives.
It should be if I'm interpreting you vision of "flat".
Jon's are nice quality and offer better structural support for the SMA jack due to the way it is built and rests on the raised shoulder or collar around the SDS100's recessed SMA jack.
I think you will be very happy with it.
jonwienke
More Info Coming Soon!
VA
The base of the adapter is the same diameter as the collar around the SMA connector, with a slightly-tapered extension that press-fits into the collar when you tighten the adapter. So the collar supports the adapter from lateral impacts, reducing the probability of breaking the SMA connector.
