brakeman67
i have a sds 100 my problem is that if turn on any of my favorites list. it wont pick up my county what do i do to fix this or is there a fix for my problem,
When you "turn on one of your Favorites Lists", I presume that you are doing that via the "Set Scan Selection" entry in the scanner's menu. Turning on one or more Favorites lists, by themselves, would not affect what you are hearing from the main database (using your zip code & location) unless, in the process of setting one or more of them to be scanned, you are turning off the main database, whether accidentally, or purpose.i have a sds 100 my problem is that if turn on any of my favorites list. it wont pick up my county what do i do to fix this or is there a fix for my problem,
Yes it's picking up my county long as I don't turn on any of my other favorites lists
Uh... yea we do.We don't need people here like him.
When you get home, go to the File tab in Sentinel and click on Export to hpe file (Favorites List). You will need to zip the exported favorites list file to be able to attach it. Click on Attach files and open the zipped file. We will be able to look at the file that was used to program your scanner. If we don't see problems with the file, ir will have to be something to do with the profile or something you did with the scanner.I have the software download on my laptop at home.
