Looking at the speaker on the front of the scanner it looks like it is covered with a felt like material (possibly for waterproofing)
Has anyone removed this covering? if so does it improve the audio quality and or volume
The speaker itself is waterproof. It has a polymer diaphragm. It's mot as flexible as non-waterproof, and that's why it sounds tinny. Ripping out the thin felt dust screen material will not help.
If the clips don't line up it's easy to solder fine wires from speaker to board and if nothing matches to hold it in place gluing or hot glue would work. I would try it but I would like to know if anyone did this and can say whether it's worth the effort.
It's full amplifier output power from the earphone jack, not restricted by limiters, and can even drive a 2 ohm speaker that will have plenty of volume and a much better audio quality than the internal one.
