SDS100/SDS200: sds 100 updating
joerobb23
rokland county n.y.
I have 2 sds 100 scanners and usually update both at the same time. How can i verify if the update to the second scanner plugged into the computer updates.It always says it does but i dont see the update bars moving on second scanner? I also installed waterfall but havent seen any charges for it . Thanks
dave3825
Suffolk County NY
Read that scanner back into Sentinel or Proscan and see if your updates are there.
When you go to use it, you will be told you need a key. Go to my Uniden to obtain the key.
