Hopefully someone can point me in the right direction. Received my new Uniden SDS 100 scanner yesterday. The scanner will not charge. When I plug the scanner in the LED lights do not indicate that it is charging (neither red or green, the LEDs never illuminate). It doesn't make a difference if the scanner is on (set charge while on is enabled) or not. If it is not turned on when I plug it in it does absolutely nothing. No LEDs, nothing on the screen at all. Additionally, the battery is now depleted and the scanner will not even turn on unless it is plugged in. Am I missing something or is my unit defective? I saw other threads where the scanner was having issues not charging when it was powered on, but I didn't see anything that fit my situation. The unit won't charge at all, period. Any ideas? Anything I should try? Any suggestions or help is appreciated. On a side note, other than this issue, I love the scanner. Reception is much better and it is an awesome upgrade from my BCD436HP.
