Have an issue I can not solve from the documentation.
I have a favorite list with about 10 systems - assigned System Quick Key keys 1-9 (a couple of systems share a key)
Whenever I have done a Scanner write using Proscan (Send MSM command, write, return to scan) - only systems 1-4 are enabled. I have to manually enable the remaining systems.
How do you set which systems should be enabled after a write operation ?
Interestingly, all lists are enabled if I shutdown/start the scanner
Regarding the System Quick Keys Status checkboxes: There is a bug with Sentinel and the scanner in this area. Unfortunately ProScan copied the same characteristics which have since been fixed and will be in the next version.
Here is the bug:
When a new Favorites Lists is created in Sentinel, all 100 System Quick Keys Status checkboxes are checked by default regardless if any SQK's has been assigned or not. When writing the favorites to the scanner, then power cycling the scanner, then reading from the scanner. All 100 checkboxes are still checked. Using the scanner in normal operation, go into the menu and edit a system then back out. Take it in Mass Storage mode. When reading from the scanner. All 100 checkboxes are now unchecked even if SQK's are assigned.
ProScan solution is when a new Favorites List is created, all 100 checkboxes are unchecked by default. A button was modified in the SQK Status tab that before checked all checkboxes and now will just check the boxes assigned with SQK's. An additional check has been added to the scanner write operation to uncheck any checkboxes not assigned with SQK's.
The bottom line is the SQK's should be enabled before the write operation so the scanner will know. To do that (in the next ProScan version) go to the System Quick Keys Status tab and click on the button "Check All Assigned System Quick Keys".
Everything above also applies to the Dept./Site Quick Keys Status tab.
