SDS 200, or 1 BCD 536HP AND 1 BCD996P2?
jlp
Middlesex County, NJ
I have a choice to get 1 SDS200, or 1 536HP and 1 BCD996P2.
I am in Middlesex County, in South Brunswick. They currently are on an analog 800mhz EDACS system.
I mostly monitor very few trunked systems, except for the NJSP and Middlesex County if something is going on.
If I get the SDS200, I have an BCT15X to use for analog stuff.
Antenna is a VHF/UHF Centerfire groundplane, mounted up around 50' above roof.
I also have the SDS100, so I'm kinda familiar with the SDS brand.
thank you for any help and advicd
IAmSixNine
Dallas, TX
Right tool for the right job.
If you have no need for a scanner to monitory simulcast systems, dont pay extra for that feature.
Its like using a Unication for VHF or UHF conventional channel. Sure it works but there are much cheaper and better options for that type of monitoring. But if i was monitoring a 700 or 800mhz multi site simulcast system, G4 is the right tool for the job. (or a SDS100 i guess).
Hit_Factor
Saint Joseph, MI
I tend to favor the new tech. Of course I can't tell you what lies ahead in SDS firmware upgrades, but it's possible and it could be a significant change of functionality. That is unlikely and maybe impossible with the older tech.
Ubbe
Stockholm, Sweden
Are there any reasons that you cannot use your SDS100?
You can only be at one place at a time so connect that SDS100 to the antenna and use it on systems where you have problems to pick up signals. The SDS100 and SDS200 have pretty much the exact same receive capabilities. Even if you only can test and compare for a shorter time you should be able to tell if it worth spending money on another SDS scanner, or if you instead can arrange to quickly connect and disconnect your SDS100 from the roof antenna.
/Ubbe
jonwienke
More Info Coming Soon!
VA
NJICS has a bunch of simulcast, so if you're listening to anything on that system, the SDS200 would probably be worthwhile.
jbix1958
SC
I'm also looking for a new base/mobile scanner, and I live in Lancaster County, SC where simulcast is an issue. While the SDS200 appeals to me, it's just out of my price range. Would the 536HP be the next best choice to fight the simulcast issue with?
buddrousa
NW Tenn
Any of the 3 could work in the right conditions but the SDS200 is the only 100% fix of the 3.
bob550
Albany County, NY
The general consensus here is that receivers other than the SDS or Unication's can have trouble with Simulcast. Results vary, though, with some reporting no trouble whatsoever. It primarily depends on your location relative to the nearest transmitting towers. As an example, I monitor a Simulcast system in my neighboring county to the east. My 536 has trouble with this due to my almost equal distance from multiple transmitters, where my G5 handles it perfectly. Whatever you choose, make certain you purchase from a retailer with a generous return policy.
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
I utilize 1 BCD536HP and 2 BCD996P2s all for local Fire/Police 700-900mhz Trunked Systems (Motorola SmartZone, P25 I and II) where I have no simulcast issues. The setup works great for me. I do have an SDS100 as well that goes back and forth to the car, but now I will be putting one my BCD996P2s in the car and will be looking to trade the SDS100 for an SDS200. Yes, new technology for the home shack.
iMONITOR
EVERYTHING
S.E. Michigan
I've always been a big advocate of both the 996P2 and the 536HP, and where I live they both did an excellent handling simulcast systems. But that's not always the case for many users.
The advantage of the SDS200 over the others is improved simulcast results, the RJ45 network port, and the display. I can live without all the colors, but they are nice. The big win for me is the size of the display/fonts! I'm 70, have lens implants from cataract surgery and I can practice social distancing from my scanner and read the display from 6 feet away! Another advantage over the 996P2 is the Micro SD storage. Like the 536HP, having the entire RR database within the scanner is priceless. The amount of memory in the 996P2 puts some limitations on how many systems can be programmed.
There's some thing to be said for having two scanners that program and operate like each other. So if you have an SDS100 getting the SDS200 would be the best choice for me.
jlp
Hi, thanks all for the advice. I ordered and have the SDS 200. Nice to just import the files already made thru Sentinel for the 100 and 536HP
DSC45
Central Jersey
I live in Somerset County, NJ. Plenty of simulcast to go around. Had the BCD536HP and the BCD436HP. Lots of distortion. My choice is the SDS200, without a doubt the best scanner I've had since the changeover to P25.
ofd8001
Louisville, KY
That would be my recommendation. The programming you have done for the SDS 100 and 536 will be interchangeable with the SDS 200, obviously. However, it may be a challenge importing that programming into the 996 because of limitations, such as 20 groups per system.
