SDS 200 Sale Price
RandyKuff
Lorain, Ohio
Quick sale at MTC in Paris, Texas…100 and 200…I won’t quote price but it is good and so are the people..have dealt with them for years..put into cart to see sale price. Alao a bunch of other good stuff….. MTCRADIO.COM.
I've bought from them... No problems at all... (y)
RandyKuff
Lorain, Ohio
Just went to MTC and dropped the SDS100 in the cart to see the price...
That is an excellent price... That will be hard to beat from anywhere else...
Brales60
Punta Gorda, Fl
Good price on the SDS100, but didn't see a 200. Good site though. Saved for future stuff.
Billd49er
Pensacola FL
OK ive decided on the SDS100 but my question is, on the Uniden Bearcatt site it list a 49buck software upgrade package, Is this really nesscary,, i though you can just punch in a zip code..... I dont mind paying if its worth it. I assume if you purchase the scanner form another dealer this option wouldn't be available, i am mainly interested in my County stuff btw
Your scanner will work right out of the box!
Uniden Custom Programmers will add county programming to your scanner. We remove the guesswork, tedium, and frustration from from manually programming your scanner for your area. Our programming department will preload your selected county/counties public safety frequencies so all you have to do is turn it on.
Your new scanner will work right out of the box.
Included :
  • Firmware update (if applicable)
  • Frequency database update
  • Favorites List setup containing public safety channels
dave3825
Suffolk County NY
Sounds like you might be talking about the paid upgrades.
The scanner will work right out of the box but it will not decode any DMR, NXDN or Provoice. To decode those, you would need the upgrade. Look in the database for your area and see if anyone you want to listen to use NXDN, DMR or Provoice.
Many of these place will also offer to create favorites lists for you, for a fee.
Does one need to sign up an register? I stuck a 100 and 200 in cart and they are normal prices. 649 and 699.
RandyKuff
Lorain, Ohio
No need to sign up....
Just did it again... Looks like the price is back to normal...
The 100 was $35 off...
03msc
RF is RF
The Natural State
Included :
No need to pay someone else to program your scanner. No need to purchased paid upgrades (DMR, NXDN, or ProVoice) unless your local area utilizes one or multiple of those modes for communications that you want to monitor. Purely up to you.
You can buy it, hook it up to a computer and use the free Uniden Sentinel software to update the database, enter your zip code, set a reasonable range (0-5 miles is advised), and you'll be up and going for analog and P25 traffic.
hiegtx
Dallas, TX
Included :
You're seeing that on the Bearcat Warehouse website. While they do sell Uniden scanners, there is no connection between them and Uniden itself.
You can do all of the above yourself, in less than 30 minutes, with a coffee break included, and save the $49.99. What they will do for "programming" is simply append the systems in your county to a Favorites list. Unless they are in your metro area, which they are not (you're in Florida, they are in Maryland), they have no idea exactly which systems are in use in your area other than what shows in the RadioReference database. Using Sentinel, you can verify whether or not your scanner has the latest firmware version.
Install Sentinel & update the database in the program. Set your Favorites list service types in your Sentinel Profile. Set your location (also done in your profile).
You can pick & choose any of these items and append it to a newly created Favorites list with a <right><click> of your mouse.
Or, once you update the database in Sentinel, then write that to the scanner, you can simply choose the service types you want, set your current, correct, location, and start scanning using the main database along with your location & range.
Billd49er
Pensacola FL
Thanks, thats the info I wanted. I've played with scanners but been 15 years, i just busted out my Pro-2006 and found out its good for acft and not much else with all the P25 stuff. Im retired and have nothing but time other than dirt bikes, to figure it out!
hiegtx
Dallas, TX
It's not really that hard. Just get used to how these scanners are set up, and it will all fall into place for you, what some call the 'light-bulb moment, when it starts to make perfect sense to you.
