SDS 200 stopping on frequency even when channel not active
galligan122
Wabash IN
Hey guys,
I am having an issue on my SDS 200. I am monitoring several systems, ones of which is Parkview Health, an NXDN system. I am in Wabash County Indiana. My question is, even with the correct RAN, the scanner always stops on 462.94375 on the Wabash site, even with no active radio traffic and wont move on from the channel. My problem is, this is the channel that I also usually do receive legitimate traffic on. Looking for suggestions on how to best remedy the issue. Thanks!!
galligan122
Wabash IN
Said frequency is a control channel. System needs to be programmed as NXDN trunked (Sentinel makes this easy). If you program the system conventionally then you'll encounter the issue you reported
SiteNameCountyFreqs
009 (9)WabashWabash463.38125462.94375c
I think that is likely my problem. I programmed as conventional. I will give that a shot. thank you!
