He copied his 536 setup, with the same range setting and location controlled scanning, if enabled, and all. The two scanners should have identical setups. The additional NAC gets set to search as default, so that the received value can be displayed, so that cannot interfere with reception.
It could be a severe case of interference that needs tweaking of the filter settings and IFX to get it running, if the interference isn't too bad.
Configure the display to show D-error and Noise level and push the system hold button when the SDS200 are on the same system that the 536 are able to receive. After two seconds it will beep and lock to the system. Then push the Fn button and the Dept button will change to Site so push that Site button to lock on to a site. Wait two second for the beep and push Fn and Site again and immeditaly begin scroll thru the sites and look at the RSSI for any signal and D-error higher than 5 for interference and Noise higher than 500 are also an indication for interference. Set the squelch to level 2. When you wait longer than 2 sec on a site you will need to push that Fn+Site buttons again to be able to scroll thru the sites again.
Push Fn+Site and wait 2 sec and the hold will release. Push on the System button and immediatly scroll to go to other systems.
/Ubbe
