tglendye
Blue Ridge Mountains, Shenandoah River
I have programmed a Harris P25 Phase II system in the SDS and bcdx36 scanners. The system is Rockingham/ Harrisonburg (VA) here: Rockingham / Harrisonburg Trunking System, Harrisonburg, Virginia - Scanner Frequencies (radioreference.com) .
The old system was a ProVoice, which of course used LCN order for the system frequencies. So I had the sites split up into separate scanlists. I continued to use method when the system changed to P25. My question is, is there anything preventing the scanner from tracking correctly if I lump all of the 3 sites into the same system/ scanlist? I don't see any reason it wouldn't work, such as monitoring a large statewide system. The only drawback I can think of is if you wanted to monitor a particular site.
