Hey, I have a Uniden HP2, 436HP, and SDS100. The speed they scan is in that order from fastest to slowest, based on my experience. The SDS100 was scanning quite slow. Definatley slower than any other scanner I have tried. I found a solution that has worked to speed up the scan speed by a bit.
First, disable global audio filter and set it to off. Open favorites, and manually turn the filter off for each site. Then, change the digital waiting time to 100ms from 400ms.
Flash to your scanner, and your scanning speeds should increase by a bit.
Hope this helps.
Hope this helps.
