I have a hp536 that receives my local PD reliably, VHF, Nxdn, conventional. records great in Proscan.
I have an sds 200, and programmed it with same info as the 536 for that channel. (both obviously have the nxdn upgrade).
The sds200 will receive transmissions ok for a while, but then just stops. Proscan shows listing in the History Logging for the relevant transmission, but no digital type shows, no Tone shows, and there is nothing in the recorder at all. No audio on the radio. It just goes deaf to that channel after a while. Other vhf (like weather ) or uhf transmissions from elsewhere play and record fine, it's just the one nxdn freq that just stops.
Signal is strong (very near one tower), I'm using "normal" filter on the sds (but tried "wide invert").
Both share the same external antenna. I tried a whip antenna also on the sds200, no change.
I deleted the system, re downloaded from the database, same.
I also have an sds 100 and see the same result... plays fine for a while, then stops receiving that channel, but Proscan history shows it did see it, just not as a nxdn or real data or something?
Anyone have any clue what to look at next?
