Hit_Factor
Sdscope -p comXSDS Bandscope I can not get this to run with windows 10 ? What must I do?
Replace X with the com port the scanner is using.
If you don't use that syntax it won't work. This isn't a win10 issue.
Yes the com port is 14 click on Run sdscope.exe it errors and disappears before I can enter
Open a command prompt and run the program from there. This is also where you can provide program arguments (i.e. the com port).Yes the com port is 14 click on Run sdscope.exe it errors and disappears before I can enter
Maybe it's time to read the instructions. It was a short paragraph on the FB page.Yes the com port is 14 click on Run sdscope.exe it errors and disappears before I can enter
I quit FB over unsolicited emails.
