SDS100/SDS200: SDS100 & 200 Bluetooth question
Dafe1er
Off in a far away place, far from u.......
I use these two for wireless audio use of my scanners and have notice that when using the setup with the SDS100 I get clear audio but, when I use the setup with my SDS200 I get clear radio traffic with what sounds like lite static during the transmission of the audio. Is there something in the SDS200 settings I might need to change? I normally don't use the 200 like this but, on this raining day, I found something to occupy my time...lol
Thanks.
Ubbe
Stockholm, Sweden
Check if the static follows the audio level by quickly changing the volume down to zero while the BT are still transmitting. Are there still static in the background?
Do you have that extra grounding piece stuck between the inner frame and the lid, then push on lid and check if it that infamous grounding issue that cause the static, especially if it sounds more like a high speed computer datasignal.
/Ubbe
donc13
Grand Junction, CO
I used to have the same problem with my SDS200. I installed a ground loop eliminator... Problem gone.
On Amazon,
BESIGN Ground Loop Isolator. $9.99
JoeBearcat
Uniden Representative
Thanks.
Which audio jack are you plugged into on the 200?
richardbritt
Northeastern NC
What's the manufacturer and model of the bt device? I assume that's a amplified speaker. Or do you have a link to Amazon etc where it can be bought? I am using a bcd436hp and it's hard to hear when driving my pickup. No Bluetooth radio in the truck. My car I just use the external audio input in the car radio.
Regards Richard
n1chu
Farmington, Connecticut
What’s a compatable transmitter for the 39g? (I see the 39g but isn’t that just half of the setup? Doesn’t it need a transmitter… what you plug into the 200?
