SDS100 and DMR
scrappy212
I upgraded to DMR and loaded the DMR code. I thought it was accepted but for some reason I do NOT pick up any DMR audio. When I come across a DMR freq, the scanner will display the CC and what type of DMR it is. No audio though. Am I doing something wrong?
werinshades
Chicago , IL
Sounds like you have it in conventional search mode and found a MotoTRBO "rest channel". Do you see Cap+ on the display? If so, it's one of the frequencies in a MotoTRBO trunking system and must be programmed accordingly.
jonwienke
More Info Coming Soon!
VA
To clarify, a MotoTRBO rest channel broadcasts a burst of data every second or so that the scanner can pick up and identify, but isn't a voice transmission. It's something like a P25 control channel, but it rotates through each site frequency with every transmission, and each burst only lasts 1/10 second or so.
werinshades
Chicago , IL
Based on the description, I think that's what the OP is seeing.
