SDS100: SDS100 and Private calls
Saint
Fort Erie Ontario Canada
I have ID search set on a MotoTRBO system and I am trying to find new tg's is there a way to stop all private calls from being logged like a Wild card so no private calls will be logged. Thanks for any information provided.
Steve
Eng74
Kern County, CA
If you are in ID search you will get everything. Try hitting avoid on the ones you do not want when the show up on the search.
Ubbe
Stockholm, Sweden
GRE/Whistler are probably holding the patent for wildcard use and Uniden will not, or can not, license it. It's the same with that Alert light that Uniden had to do differently with a timeout after 3 seconds to avoid a patent issue. Probably many more things that we think are stupid but are done to go around patents that Uniden do not hold.
/Ubbe
Saint
Thanks for the information I was just wondering if there was a way get a wild card in but I guess not I'll work around it thanks
werinshades
Chicago , IL
Try adding a new Talkgroup i0 (small eye, zero). Then scroll to Permanently Avoid and see if that works.
