I created a Favorites list on the SDS100 and on that list are only two systems. CT State Police (labelled in Sentinal as Motorola) and the newer Connecticut Statewide Emergency Radio Network (CSERN).
I also have my other scanners locked onto the same system so I know when something is being transmitted.
The other two are talking away as usual. The SDS is silent.
Correct me if I am wrong but the database already on the system is from RR right? I don't have to pull a special database from somewhere?
The vendor I spoke with where I bought it said the only advice he had is the same as all of you guys have already suggested (making favorites list, moving locations of the unit, make sure antenna is not the stock one, etc.)
I can't help but think this is some kind of programming or location issue. Granted, if you are using the main database, it should not be tghe database, but its not impossible.
Make sure that the SDS has your correct location and desired range. For the SDS100, you are NOT hearing traffic with main database & location? But are on your HP-2 & 325P2? I have seen a handful of cases where the main database was incorrect or incomplete. These were occasions where, somewhere along the line, updates or corrections were maid on RadioReference, but for unknown reasons, those changes did not trigger an update on the main database. In other words, the changes/updates were basically ignored. On the rare instances that happened, I looked at the information in the main database in Sentinel, and found there was a difference between the HP-2 Sentinel db, and that used by the x36HP/SDS100.
Also, you might try this:
In Sentinel for your HP-2, with your location, range, and Service types set, click on the Edit drop-down menu.
Select the option to "Add channels in range". That will generate a Favorites list with what the HP-2 would be scanning with your current profile settings. Give the new list a name of your choice. 'Test', HP-2", whatever.
Now, still in Sentinel for the HP-2, click on the drop-down file menu. Select "Export to hpe file". Sentinel will ask you which list to export. Choose the 'in range;' list you just made. You'll then get a pop-up window with a listing of the systems within the list, to choose which to export. I would select all of them, but at least the Connecticut State Police ones that you are not hearing on the SDS100. After marking the systems to export, click OK to proceed to the next step.
You'll get a window to set a name for the export (the default is the name of the list you're exporting, but you can use a different name if so desired). Once you've picked the name, hit save to finish the export process, Be sure and note where the file is being saved.
Now, in Sentinel for the SDS100, click on the File drop-down menu, and select 'Import from hpe file'. Sentinel will ask you to either pick an existing list to take the imported information, or you can create a new list. Make your choice, and click OK.
At this point, Sentinel will pull up a window for you to choose which hpe file to import. If you do not see your file created in the HP-2 Sentinel, browse to the location where the file was saved. Once your exported file has been located and selected, click Open to finish the process.
In the Sentinel profile editor, for the SDS100, be sure that your imported Favorites list is set to be downloaded to the scanner, as well as monitored. Also make sure that "Monitor Full Database" is not checked (that's on the same tab as where you specify which lists are to be downloaded and/or monitored). Write the new favorites list to the SDS100 via Sentinel. (While in the Profile editor, before writing to the scanner, be sure that the same Service types as used on the HP-2 are enabled.)
Now, when scanning the imported list, your SDS100 is programmed with the same channels that your HP-2 would use. Are you now hearing things previously missed? On the scanner , press the Menu button (bottom one on the left side of the scanner). In the Menu screen, scroll to and select 'Manage Favorites'. Select your newly created/downloaded list & press
E.
In the first Edit screen that appears, select 'Use Location Control'. Set Location control to "On" and then try scanning again. Are you still hearing the same expected radio traffic as your HP-2 & 325P2? If so, then something is wrong with the database in your SDS100. If you no longer hear the same channels/talkgroups, then there is an issue with your location and range settings in the SDS100.. It may not have been saved correctly, or was typo'd. Try resetting via the scanner's menu and see if that makes a difference.)
