Does anyone have any recommendations for a good antenna for the SDS100 to be used in this area? https://www.radioreference.com/apps/db/?ctid=1962
Thanks.
Thanks.
Yes and Yes.Also, one more question - would it be possible to hook up the SDS100 to an outdoor antenna when I'm at home and use something like ProScan to stream to my laptop so I can get increased coverage via the outdoor antenna?
I know the SDS200 is more ideal for this scenario but I would prefer the SDS100 for portability to take when going out of town...
Thanks again.
Sounds like this could take awhile![]()
Thanks for the info. I guess my next step is to research outdoor antennas that has the wide coverage....
Then I have to decide cable type and where/how the antenna will be mounted.
Good advice on the Diamond discone. When you compare you will find a Diamond 3000 and the NJ130. The 130 is the best for monitoring, as the 3000 is tuned for the stratosphere and transmitting etc etc, really no need for this unless you are into satellites. The 130 is a great, durable antenna that I have used for years with great results. The LMR-400UF is about the best you can get, good advice there. If your target is P25 systems you might want to upgrade your ducky to a Remtronix 800mhz antenna at some point. Good luck with it and have fun!
JD
kf4anc
I have a run of 100 feet running out of the house to my Diamond Discone (Ditto all the above comments) and get great results. At one time I have used a 150 foot length with very little apparent signal loss.Is there a recommended max cable run if using LMR-400 cable?
You would need an N female to SMA male as your pigtail.
Sent from my SM-J327V using Tapatalk
USA Coax - Custom RF coaxial cables by MPD DigitalThanks - are there any online sellers you'd recommend for pre-made cables? I can order the LMR-400UF from the Amazon link but can't seem to find around 10 feet of the LMR-240UF N female to SMA male...
D130NJ is the Diamond model number.Thanks for all the good advice. I'm actually having a difficult time finding a company selling the NJ130 - any suggestions?
Also any advice on how to mount one? I'm assuming on the roof would give the best results, just not sure about how the wife will like that idea.![]()
