SDS100/SDS200: SDS100 Antenna Suggestions
Mboy00
Hello all,
I am having issues with VHF reception for my SDS100, and I am looking for some suggestions for antennas that can reach high distance but still be somewhat portable with the scanner.
Thanks!
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
Consider the Comet SMA-W100RX, confirmed to fit my SDS100. Elbow joints allow it to be folded alongside the unit (yes I know BNC version is pictured, but same idea)
1645398007811-png.117034
jte3470
I have used a Diamond RH77CA, however, I ordered a Comet BNC-W100RX. I have a similar antenna on my Icom IC-R30 and it works well.
Ensnared
Waco, Texas
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
'High Distance' as the OP wrote? Nope not when running indoors or around a lot of obstructions. It's physics - if you want to really reach out you need an antenna that is above the obstructions and fed with good quality coax. An antenna surrounded by trees and buildings are likely to have problems. That's not 'portable' I know but the 2 are almost oxymorons of each other. Mike
jte3470
@Whiskey3JMC I ordered the BNC-W100RX from antenna farm and got it in today. HOLY COW!!!! The RSSI compared to my RH77CA is at least 15 dBm. This is perfect for what I'm listening to. I haven't tried it on 70cm yet, or 800 Mhz. 2 meters is fantastic. Thanks for the suggestion.
rlex
I have RH707 for "portable" mode, RH77CA for desk mode (sadly, don't have external antenna). Both are BNC versions. RH77 was improvement over RH707, but only in voice clarity, especially in analog. Not much difference about distance. Now i guess i should order BNC-W100RX too... Never hurts to have several antennas.
