cozway
I bought a Uniden SDS100 used about 2 weeks ago. The scanner works beautifully, great sensitivity, etc. except for one thing. The audio seems to clip on peaks on some receptions causing substantial distortion. I've seen posts that mention poor speaker connections, however this is not the case on mine. I've tried external speakers with the same result. Also, recordings have the same clipping and distortion. This only happens with approximately 30% of receptions. I would have liked to attach an audio file recorded on the unit for an example of how it sounds but I wasn't able to. I don't know if it is a defective unit or if I just need to set some option or filter differently. Any help or advice would be appreciated.
