Good afternoon.
My SDS100 just came back from the Uniden repair shop and seems to be running just fine, at least, for the time being (I'm keeping my fingers crossed, however).
The repair documentation says that the tech "cleaned connector contacts," which I'm guessing has something to do with the dreaded SDS100 cold-solder-joint issue. Nothing was mentioned on that slip of paper about the J401 part the customer service gentleman said was mentioned in the technician's notes when I called earlier this week.
I dug out my old BCD436HP as a temporary substitute for the SDS100 and made some updates and changes to the '436, which I've downloaded to the SDS100 (Sentinel is a great tool).
I'm going to take some extra precautions to hopefully prevent a recurrence of the problem that I suspect was the result of repetitive hot/cold temperature cycles. For example, I'm going to forsake the nylon carrying case I was using before and use a soft-leather case I bought from ScannerMaster that has some extra vent holes in it to help dissipate heat.
Thanks (especially to Jon Wienke and Ubbe) for all the helpful information you shared with me about what was probably causing my problem with the SDS100 . . . I'll keep you posted.
-Johnnie (KC5IGH)
-Johnnie (KC5IGH)
