SDS100 Close Call and DMR
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
can anyone provide guidance / steps on how to set up the SDS100 in Close Call mode to pickup on a very close DMR signal? I have the DMR and NXDN upgrade. I have successfully been able to hear NXDN, P25 and Analog using the CloseCall mode. I cannot get the SDS to recognize on an open non-encrypted DMR signal. I have both a MotoTrbo and Kenwood NX-5000 series sitting near me and neither get picked up on the scanner in DMR, but do on P25, NXDN and Analog. What am i doing wrong? thank you. Have you successfully picked up DMR in close call?
Ubbe
Stockholm, Sweden
If you try to pick up your own DMR transmission it will not work as it is a pulsating signal and close call needs a constant signal to be able to work out the frequency. Your other modes sends out a constant signal from your mobiles.
To get a closecall signal from a site it has to be conciderable stronger than any other signal in that frequency band. You probably have too many transmitters in that band that are too strong. I have a Optoelectronics Scout40 and that captures frequencies even when there are several transmitters in a site and usually alternate between them displaying the different ones. Close Call can never do that but Scout also costs almost as much as the whole scanner.
/Ubbe
