There may not be a lot of differences, even though there definitely are differences like the LAN connection and the bigger screen, but some people want a base radio and some a handheld. And then there are people like me that want both.
I am glad for the larger screen because I am legally blind and I am stuck at my house most of the time. I realize I fall into a small group but I like having a base radio that just sits there and is hooked up to a computer and an outside antenna. I'll be putting a lot less wear and tear on my SDS100 or even my Unication G5 if I have a dedicated base radio hooked up to my outside antennas. It's definitely not a cheap thing to do and is more or less $2,000 to own a setup like those three receivers. But with the bigger screen, it would make it much easier for me to see and therefore be able to use my scanner faster. And with the proper software, and I'm trying to learn about ProScan but they won't email me back, I could have the radio display sent to my big screen TV and be able to listen in the living room rather than have to be sitting at a computer.
If there's one thing I hate the most it's hearing something and not being sure what channel it was on. I set my replay on my SDS100 to 60 seconds. So I do have a way to go back and see what I miss but at the same time I miss what is currently coming over the radio also when I have to do that. Plus, if you're already recording you can't go back and check what you might have missed until you stop recording. It might not be the radio, and I'm talking about the SDS200, for many people but it is definitely something I would like to have.
I also was comparing the latest Whistler radios to the Uniden SDS200 and SDS100 and Whistler just didn't have what I wanted or a way of programming that made sense to me. I'm not knocking Whistler and they sound like they do a decent job for most who have one. But Uniden has the edge not only in features but also in the look and display in my opinion.
So yes, I definitely would like to have the new base model as long as it works right and I have no problems with it
I guess it's just a matter of taste, opinion, and needs or wants in an individual that determines the criteria for needing or wanting one.
And one last point I would like to make is this. I don't know if this will be the case in the new base scanner or not? But in past scanners, and I've had many over the 40-years of scanning, the base models usually have better sensitivity and selectivity making them better receivers. I can't say whether or not this will be the case here but I imagine it could be. I guess time will tell...
Brian (COMMSCAN)
Sent from my SAMSUNG-SM-G930A using Tapatalk
