This option was added to the Waterfall upgrade for the SDS100 & SDS200.
RF Gain The scanner’s RF Gain defaults to the recommended value of Automatic. This setting is preferred and adequate in most cases. The user can adjust the RF gain by selecting one of 16 available gain levels, numbered 0 through 15, or can choose Auto.
In an area with nothing but weak signals, the user may increase the RF gain in order to receive more signals. In an area with very strong signals, the user may decrease the RF gain to compensate. Be aware that changing the gain simultaneously affects the strength of the background noise as well as signals.
NOTE: If you increase the gain too much in a strong signal or noisy environment, the display will saturate and distort, making it impossible to obtain correct information. To change the RF Gain setting, press the Function key and press the zero (“0”) key on the keypad, which is marked 0 LVL. The setting is changed by turning the knob.
