SDS100/SDS200: SDS100 has quit charging
YoShep69
Central Illinois
This morning the red charging light went out. The scanner is no longer charging. I've tried several cables and chargers, no luck. The cables and chargers all work as the scanner is showing USB2 voltage of 5.01-5.08.
Any help, suggestions?
Thanks,
Greg
WX4JCW
Stow, Ohio
Could be the charger I had 2 that didn't work and the last one did, also charging while on has to be reset each time a low voltage error occurs
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
XPR7550 - SDS100
jonwienke
More Info Coming Soon!
VA
If the scanner detects a low USB voltage condition it will helpfully reset the charge while on menu to disabled. Recheck your menu setting.
mike1988
Brandon Fl
I'm having the same issue. Normally when scanner is done chariot goes to green light. Now I just looked at it and no light at all. What should I do?
jonwienke
VA
Check the Charge While On menu.
