SDS100/SDS200: Sds100 missed comms related to close call feature
racing1
When using close call priority the RSSI meter blanks out a lot and many comms are missed/interrupted. But when close call is OFF or set to DND. The scanner works fine. I'm on official stable firmware [no beta]. Does anyone else have this issue?
Sent from my SM-G965U using Tapatalk
jonwienke
More Info Coming Soon!
VA
That's normal. Priority stops everything, even if a transmission is in progress, and checks Close Call. DND only checks Close Call when no transmission is being received.
racing1
But the audio cuts out every other second. With no nearby transmissions trying to be received.
jonwienke
VA
That's just the way Priority works. Even if a transmission is in progress, the scanner will drop it and check for close call hits every 2 seconds.
racing1
Why is it also doing this DND mode?
jonwienke
VA
It doesn't. If transmissions are cutting out, you have weather priority or priority scan turned on.
jonwienke
VA
Menu \ Priority Scan \ Set Priority
Menu \ WX Operation \ WX Alt Priority
Both should be OFF.
