JoeyC
Senior Member
My observations with the SDS100 using the Remtronix 800 antenna in various locations around my house located south of 8 and near the 15.
It has a hell of a time capturing the cc of the NextGen West site (45) sometimes taking MINUTES to lock on to it, and then when it does, it is hit or miss whether it maintains a hold. When it does lock on, I get 4-5 signal strength bars, an RSSI of between -55 to -65 using the W-INV filter and NOISE all over the place usually varying between 4000 and 48000, mainly 5 digit numbers and it will SOMETIMES hold that for minutes at a time and then sometimes it drops and reacquires the cc every few seconds. Then there is the legacy RCS site, where I can lock onto the North cell just fine and maintain a NOISE level averaging 100-500 with crackly and staticy analog reception with a -60 RSSI reading. with the W-Norm filter. The digital sounding audio is acceptable with occasional digital blurbs.
On the NextGen South site (41) I am getting an RSSI of -48 to -60 on average with NOISE mainly 2000-9000 with occasional spikes to 25000 with the Inv filter. Audio is much better consistently than from site 45 with fewer digital decode messups.
On the legacy RCS South site I get an RSSI of -60 to -88 with average NOISE 200-700 with occasional spikes into the 5 digit ranges using the Norm filter. More often than not, the RSSI is rock steady at -60 and on occasion will fluctuate. There does not appear to be any NOISE difference when the RSSI changes compared to when it is steady at -60.
I don't understand why my NOISE levels on the NextGen would be so much higher than on the old RCS.
I have chosen the filters I use for each site based on the one that gives the best RSSI value and fewer Errors. Perhaps I should be looking at NOISE levels also? Instead of?
I love the way this thing decodes and sounds in comparison with that 536HP and the 996 that I have in the car which doesn't work worth a damn on the newer systems but it sure doesn't make any sense to me when I compare the values I get from the display when comparing the two.
