SDS100 or SDS 200 Reluctance
fasteddy64
Gulfport, MS
I've seen your posts and if you would have done some homework, you would discovered all this before you purchased. Maybe a swap or sell it and purchase a 436/536 for the Provoice upgrade. The 70's are long gone, I stood in line at Radio Shack and purchased crystals but also have kept up with technology. As it says, been scanning 40+ years now.
I did my homework, and I arrived where I did because it was my only choice because of Provoice.
When I lived in Texas I was a Whistler user, just like their trunking scanners better.
Now I live in Mississippi and Uniden is the only choice.
One of the locals has good luck with a Uniden 325p2 handheld and I may look into one of those.
fasteddy64
Gulfport, MS
I started scanning in the early 1970's any scanner geek should love the SDS display all the system data all the signal data all the color.
Nope.
Been scanning since the late 70's.
Not a fan of the SDS displays. The colors do nothing for me. All the other junk on the screen doesn't seem necessary to me. I keep them on the simple display.
MStep
New York City
Nope.
That is the beauty of the SDS series. Not only can you switch off the colors and go from black on white or white on black, but you can pick and choose what you want to display on your screen.
Omega-TI
Ω
Washington State
Yes, configurable! It gives us old men something to play with and explore.
natedawg1604
Colorado
Some of are kind of stuck with this series of scanner. My area is primarily using an EDACS Provoice system with no indication of changing any time soon. If it weren’t for that I don’t believe I would be using the 100 and 200. I just don’t like them. Don’t like the display. Don’t like all of the settings and adjustments. I would rather enter my frequencies, hit scan and forget it.
Oh well. It is what it is.
Unless you are referring to a very special system setup by an Amateur radio club, I will guarantee you that system is going away sooner than later. There are relatively few EDACS public safety systems left in the country, especially those using ProVoice. And those that exist are rapidly going away. The underlying technology has been end of life for many years and is no longer supported.
Also, the only scanners that support ProVoice are made by Uniden, specifically the BCD325P2 or newer series'. So I'm not sure how you're monitoring the ProVoice TG's unless you're using an old Harris radio or DSD+.
Pretty much everyone who monitors an EDACS system should plan for it to go way sooner than later. Ever notice how there are huge quantities of Harris P7100/7200's floating around on fleabay with only EDACS options enabled? (I'm not sure why anyone would even sell or buy those things, they are worthless paperweights).
fasteddy64
Gulfport, MS
The system here is our local public safety system (Harrison County, Mississippi)
I am sure it will go away sooner or later but as of now, there has been no news as to when it will happen.
The equipment I am using to monitor it are the SDS-100 and the SDS-200.
My comments earlier are about the fact that I just dont like either scanner frankly. Ugly displays. Crappy audio. A lot of settings and functions that I would rather not have to mess with.
I was very involved with another EDACS system (Abilene Texas) from the planning and implementation of it (2005/2007) till it's retirement in 2019.
It had a good run, was very robust and reliable and were sad to put her to sleep.
hiegtx
Dallas, TX
Yes I am aware.
I went with the SDS series to deal with possible simulcast issues.
Eventually, your local ProVoice system will be replaced, probably by a P25 Phase II system using simulcast. At that point, the SDS scanners are your best choice for monitoring. Besides using the simple display modes, you can edit them to remove clutter that is of no interest.
The audio on the SDS scanners don't concern me. However, I spent too many years in very noisy environments, including over a dozen working on buses at DFW Airport, so my hearing is not the best.
