I've had some free time today and wanted to do an evaluation of the various systems on this SDS100.
I currently have the radio on Volume 12 and Squelch 2.
System 1 is a P25.
System 2 is an Analog.
System 3 is mix of P25, EDAC, and Analog.
System 1
It doesn't pick up really, it like shows a constant skip when a talkgroup pops up. I've only received one full conversation between a unit and dispatch so far. The D-ERROR is usually --- or 40, NOISE is large numbers and -50 RSSI. It says P25 and Slot 1 or 2 when transmitting and its an NFM band.
System 2
Analog - D-ERROR and NOISE very high in thousands, --- RSSI. No activity as of yet.
System 3
P25 - is normal. D-ERROR is 0, NOISE in very low 3 digits, and -45 RSSI. It says P25 and then LINK when transmitting and its a NFM band.
EDAC - is normal. D-ERROR is ---. NOISE in very low 3 digits and -82 RSSI when transmitting -45 when not. its an FM band.
Analog - appears normal. NOISE very high in thousands when transmitting and RSSI -75.
Can the time between systems also have an effect?
