Right now its -45dBm, then randomly it blinks. When I have squelch on 1 - NOISE is 100's-400's, I just raised squelch to 3 and NOISE is now 1000-5000's, same RSSI -45. I'm picking up one talkgroup but it keeps blinking as if its not fully picking up.
-45dBm is a very strong signal reading. Try turning on the attenuator to see if anything changes.
If the signal is weak and on the low edge of what the scanner can receive, somewhere between -100 to -120dBm.
-45dBm is super-strong. The scanner RSSI indicator is not lab-accurate, but it shouldn't ever be 60dB wrong.
When you ship a scanner to Uniden, they usually request that you ship just the basic scanner. Remove the battery, SD card, and antenna. Leave a note inside the box with a detailed report of your problem, the model# and serial# of your radio, and your name, address, and phone#.
Before you send the scanner in, I want to make sure I understand exactly what is happening. Please verify that all of the following are correct:
If any of these are incorrect, please point out which.
- You hold on a site on a trunked system, and get a RSSI reading of -45dBm.
- With squelch set to 1, noise in low, 200 or so, and you receive traffic.
- With squelch > 1, noise increases to > 2000, and you stop hearing traffic.
- When you hear traffic, RSSI shows below -100dBm (e.g. -108dBm).
- Turning on the attenuator stops all reception, RSSI shows "---".
If you return it to Uniden, contact support and get a return authorization. They will send you a mailing label to print out and put on the box.
Before I responded, I tried one more thing.
I moved the radio into another room (room with the least electronics). When I switched systems, and only scanned my local police which is also P25, everything worked perfectly normal. I have attenuation on and squelch set at 2. Under these conditions the NOISE remained in the 200's & 300's and RSSI -45 with consistent "DATA" and full signal bars.
When I switch to the problematic system, everything happens that you mentioned above.
What I also find interesting is that my first week with this radio, the problematic system did not come in period. Not until I left the house and stopped at a place near the tower that is when I began picking up talkgroups. Since I left that establishment, this system has been picking up fine at my home. I don't know if the antenna had to like "link" up with the tower or what. But still, there are times I receive 95% of all transmissions on both systems but randomly some may be broken, half distorted, or rarely but missed.
So lately, I just have filters and attenuator both set to off, squelch set to 1 so that they all work and I don't have to switch back and forth.
You generally want the attenuator off, because it weakens the signal by about 20dB. What happens if you monitor the trouble site with attenuation off and squelch on 3, but go a few miles away?
