SDS100/SDS200: SDS100 Recording Question
usmiladim
Macedonia Ohio
Good Evening
when recording does the SDS100 record every transmission that are in current favorites playing?
Thank you
hiegtx
Dallas, TX
Good Evening
Thank you
When set to record, the scanner will record any transmission it receives, regardless of whether that is from one of your Favorites lists, or from the main database (presuming you were not using a list, only location, range, & the full database).
If you want to only record specific transmissions (certain conventional channels or selected talkgroups), you would need to control that by having your scanner connected to a PC, and using ProScan or ARC536. You cannot select specific channels for recording on the scanner alone.
Note that if you want to record 'everything' on the scanner, but selectively listen to only certain channels or talkgroups, you can use the Universal Scanner Audio Player on your PC to access your recordings, then sort so that you only listen to what is of interest.
usmiladim
Macedonia Ohio
Thanks Kindly
hiegtx
Dallas, TX
Thanks so much. After the 240 minute option does it automatically create a new file and continue recording to it?
Yes. That 240 second (max) for the "Replay" option will drop one or more older transmissions as new ones are recorded.
mc48
Monroe County, NY
If you want to record continuously simply press function, record, yes and it will record until you press those keys again.
