SDS100 Recording Times
msmart2k
I've had my SDS100 for a couple weeks now and have only recorded for a couple minutes to test it out. Works great. I'm thinking about upgrading to my 16GB MicroSD I already have, or maybe buy a cheap 32GB Samsung EVO. I plant to backup any interesting recordings to PC.
Does anyone know how long I can record on the OEM 8GB? How about 16GB or 32GB? Other than recording, is there any other benefits to larger MicroSD card?
Ubbe
Stockholm, Sweden
30 sec are 0,5MB and on a 8GB card, if it is empty, you can have 16000 sec which is 4,5 hours.
The bigger the card the more are the file writes spread out, less writing on a surface.
But I don't know if it's possible to wear out a card due to too many file writes. I've had my original Uniden card in my HP1 for 10 years with a constant recording on for at least 4-5 hours every day. Card failures must be of some other reason than wear and tear from storing audio files.
I believe it's still a problem when the number of recording files start to build up that the scanner responds much slower and feels almost dead from the keypad.
/Ubbe
msmart2k
4.5 hours recording is plenty for me so if I upgrade the card it will be only for reliability.
Thanks Ubbe
ofd8001
Louisville, KY
The recommendation is to use a high endurance type of card. These tolerate read/write cycles better than the others, thus extending their life.
Given the minimal price difference, it's also best to get the higher capacity so you aren't so rushed to copy files. A spare or two is good to have just in case you get some bad power hiccups and corrupt a card.
Ubbe
Stockholm, Sweden
SD cards can have have up to 128kB in one memory page. It doesn't write to the same page all the time but advance to the next free page with each write. It continues to use the next page till it finds the end of the memory area and starts to write from the beginning of memory again. That's one cycle.
A 8GB SD card has 64.000 pages, if they are of a 128kB size, it will use 4 pages for that 500kB 30 sec audio sample. If you continuously record it will take 16.000 writes of 4 pages to reach the end of a 8GB SD card, that's one write cycle. Some SD manufacturers state something like 100.000 write cycles of lifespan for one memory page. It should be impossible to wear out a SD card.
Sandisk has a 30 year, or lifetime, warranty for their SD cards as the number of maximum writes are so high that it would not wear out during your lifetime of recording HD video. Different speed classes of SD cards are defined at writing speed of around 50MB per second but in a scanner you have less than 1MB per second when reading data so high speed SD cards are not necessary.
Your only critical specification for a SD card for scanner use could be operating temperature and the quality of manufacturing. Both low quality SD cards and those specified as high quality are failing but it is not from wearing them out by too many writes to the SD card. Always have one spare SD card so you don't have to run out and buy a new one and also keep an updated copy if you cannot reprogram one easily, like when you are in a vehicle.
/Ubbe
msmart2k
Great advice. I temporarily replaced the 8GB OEM with a 16GB that I had to test the process. Worked fine. That should hold me until I can grab a Samsung PRO Endurance 32GB. I see it on Amazon for $9.99. Maybe I'll get a couple.
