SDS100 Scanning Issue
chriswc
Just got the SDS100 scanner but having issues scanning on it. I loaded a number of favourites with sentinel however when I load the favourite lists it scans but does not pick up anything. I have ensured the service types are all selected. I have only been able to scan p25 phase II system successfully.
jonwienke
More Info Coming Soon!
VA
Turn off your favorite lists and turn on the main database, and set range for 5 miles. Do you get anything then?
werinshades
Chicago , IL
Menu..Set Scan Selection...Select Lists to Monitor. Double check settings.
chriswc
I tried the main database last night and still wasn’t getting anything. I will try again tonight. It’s strange it’s only picking up stuff from one system.
chriswc
Already have all the lists selected. I can scan and hold on different talkgroups but am not receiving anything on those talk groups. Any specific settings you suggest looking at ? Thanks
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
What's your location and exactly what systems are you attempting to monitor?
Houk
Sent from my Moto G (4) using Tapatalk
chriswc
In Canada. I have loaded a couple of the EMS talkgroups and a couple of other system
jasonhouk
Uniden AlphaMan
Marion, Ohio
Canada is very large and "a couple of other systems" is to vague in an attempt to help you.
Houk
werinshades
Chicago , IL
Make sure you assigned a Quick Key number to each system, and they are activated.
phask
zanesville
Yeah - as others asked - where are you? Province - county?
AND have you updated the firmware and database?
W1KNE
Fully Encrypted
New England
Make sure the "service types" you're trying to monitor are turned on.
i.e. EMS Dispatch, EMS-Tach.
When the scanners come new, a bunch of them are default to off.
chriswc
I have already enabled all the service types. It’s quite strange I can load the favourite lists and hold on specific talkgroups but do not receive anything. I can only hear things on one system.
werinshades
Chicago , IL
When you press Scan, you're seeing "Nothing to Scan"? The good news is it sounds like it's programmed in. Make sure everything has a Favorite List number assigned. You previously stated all Scan Lists are enabled, Service Types all enabled. Have you previously programmed with 36xp scanners?
chriswc
I have programmed on a 436hp before. Currently it’s out for repair for the clock battery so I can’t see if it is just the SDS100 that is having the issue picking up anything.
werinshades
Chicago , IL
One thing I quickly discovered I didn't need was my Atteunator. It wiped out many of my digital systems and used it frequently on my 436 & 536.
theoldcop
Wilmington, NC
Make sure your lists are set to monitor and download in your Sentinel profile settings.
Cantafordit
Cork, Ireland
Hi Chriswc, Did you ever get a solution to this issue, I am having the very same problem. The scanner worked fine for a few weeks and now it scans my favorites but never stops at anything. I have even keyed a PMR radio right next to it and it just keeps scanning. I am in Ireland so the database is no use to me and sending it back for repair would be a pain. I hope there is an easy solution.
UnidenSupport
Wisconsin
The first thing you should always do if you are having reception issues is to update your database and write it to scanner.
try the full database and see if you are getting things now. If you are, remake your favorites list and write that over.
If this does not help, Give us a call at 1-800-297-1023
