SDS100/SDS200: Sds100 settings/options
TxScanner
I’m just wondering, if you can get into settings on the SDS100 like i can on the Home Patrol 2, where i can go into a channel and adjust the Volume offset, etc? If so, how, thanks.
Sent from my iPad Pro using Tapatalk Pro
u2brent
OAMPT
KRWDPAXKRS1
Yes,
menu
manage favorites
select the FL from the list
select review/edit system
select the system
select edit department
select the department
select edit channel
select the channel
select the option you wish to change.. delay, alert, volume offset, ect..
change the value
hit enter (or tap volume) to save change
back out by tapping menu..
Or use Sentinel...
u2brent
OAMPT
KRWDPAXKRS1
Also, you can access these options by pressing E while a channel/TG is active..or on hold..
