SDS100/SDS200: Sds100 shutting down
Whospoonbill
I know I put up a lot of post but my gut is telling me to ask this is it normal for my sds100 to shut down when it gets hit up against something. Something like that just happened I don’t know what but one minute I heard sound the next i didn’t and I try the channel knob it wouldn’t turn the screen so I had to turn the power back on. should I send this refurbished sds100 back to saddle creek to get it look at it might of hit against the arm of my char it’s wood and it it barely was bad if that. and it was in a radio holder to should I be worried about damage what are the signs of it cause I’m trying to take better care of this
hiegtx
Dallas, TX
The most likely reason for the unexpected shutdown when the scanner gets "bumped", would be an intermittent connection of the battery. Do you have the large battery, with the correct cover. or the smaller battery & cover.
Does the battery compartment cover fit tightly, or is there a little looseness? If you gently shake the scanner, can you feel the battery shifting around under the cover? Any chance that the battery compartment cover got too warm somehow, and warped enough that the battery could be loose enough to break the connection? You might also check for any sign of corrosion or other contamination on the contacts of the battery, as well as the ones on the scanner itself.
I would think it's unlikely that the memory card is at fault. Doesn't hurt to check, of course, but if the card was loose & shifting, I would think that it's data would get corrupted, and a simple re-boot is not going to fix that.
Whospoonbill
Also I had to restart my scanner cause it says it link but I didn’t hear no voice and it keep saying link and it was just stuck on link it fixed that
TonyMcN0BPA
Hannibal, MO
Yesterday I noticed that my SD100, new in August 2021, was failing intermittently. Discovered that the plastic "spring" that is the battery clip (I have the large battery) has failed. It no longer holds the battery cover tight to the unit. Does anyone know if there is a replacement metal clip or improved plastic clip available? I hate to send it back to the factory for this because of all the expense to them and especially to me, as well as the inconvenience. But I will if that is what it takes to get it fixed. It may still be under warranty, but when I call the factory customer service number I get a message that everyone is in "training" today. Anyway, check your battery door clip.
tvengr
Well Known Member
Baltimore County, MD
The battery clip has a history of failure. Call Uniden again and ship it back while still under warranty. Uniden may send you a shipping label. When removing or installing the battery, always hold the cover tightly to the body of the scanner before snapping the battery clip into place.
mc48
Monroe County, NY
Check on ebay, you can get them for $11.50 shipped from bartsscannerparts. I never ordered one of those but have ordered from there before and they ship fast.
TonyMcN0BPA
Hannibal, MO
Thanks for the tip! After the weekend I will be calling factory customer service about replacement under warranty. Given the history of the failures, I may go ahead and order a replacement from the folk you recommend also. Just in case...
