SDS100 Struggling with Chino PD Motorola
I'm struggling un understanding how to program my radio for both CONFIRE and Chino (not Chino Hills) PD. Favoriting the list directly from Sentinel results in a "Nothing to Scan" error on the SDS100 - monitoring and download are enabled.
I've attached a few images that hopefully show an easy mistake that I've overlooked. I'm fairly certain it has something to do with "Sites" showing up empty, but I'm not familiar enough with the Motorola systems to figure out the answer to that one.
Eng74
Kern County, CA
You need to update Sentinel. SBCoFD is on a P25 system now. That is the old analog system that is not in use anymore.
tsalmrsystemtech
Also, all LE are non listenable anymore in SBDCO. Just CONFIRE is digital in the clear.
So the bad news is you will not be-able to listen to Chino PD. At least SBDCO FIRE always has good calls all the way to the Nevada and Arizona border with a lot of helicopter rides to the hospitals. Just make sure you program the Mountain Simulcast system in your radio so you will get all of the CONFIRE talkgroups to listen to. Good Luck
