What changes that causes issues between models?
I've given up. I added a 700-800 mhz antenna and the reception was poorer than the standard rubber duck type that came with the scanner. The reception of the SDS100 is not sufficient no matter the location in or around my home while my 396XT receives the trunked transmissions without any problem. I am returning the scanner with great disappointment. It did a great job on the simulcast system when I was in Flint but that doesn't do me any good at home.
You literally can do a save as on an x36 profile in Sentinel, select it as SDS100 and write to scanner. No need to adjust anything and it will just work, but you do want to go in and tweak some settings specific to the SDS100.
The new firmware makes a big difference when receiving weak signals. Have you tried that?
The latest beta is 1.02.05a. You have to manually load it from the link in the open beta firmware thread.
https://forums.radioreference.com/uniden-tech-support/372091-sds100-firmware-1-02-05a-open-beta.html
Follow the instructions in the first post.
Had a similar problem. My Home Patrol-2 was receiving much more traffic than the SDS100 when side by side. Went through the programming thoroughly. Auburn Hills area. It's got to be something with MPSCS simulcast in this area. Returned my SDS100 until it can be sorted out.
I walked a guy through that exact problem on MPSCS. The SDS100 can program separate NACs for each site. Some of the NACs are wrong in the RR database, and so the SDS100 wasn't receiving traffic from the sites where the wrong NAC was listed. Correcting the NAC fixed the problem. The issue was not the scanner, but bad programming data.
pjbracing, your issue is probably the same thing.
Thanks but I not think it was the NAC's as I was able to receive MPSCS very well without any programming changes when I left my house and drove only a short distance away, still connected to the Holly tower.
