Are these systems that you created manually? Or were the new systems appended from the main database?
When you say that "they do not appear", is that because you don't see their names show up on the display with the SDS100 scanning the list?
You might also export your Favorites list into an *.hpe file, then attach it to a post. That eay someone can look at it and see if something needs to be changed or added. To do that, once you create the hpe file, <right> click on it and, on the 'Send to' option on the pop-up menu that appears, select "Comprised (zipped) folder".Attach the zipped file to a post.
