Hello all,
I have been doing some testing the past few days after discovering something odd. My SDS100 suffers from very bad interference on VHF/UHF (800 MHz seems ok) while my vehicle is in motion. At first, I was thinking my car was likely the culprit, so I began testing with a mag mount on the roof as far away from the engine as possible. The noise is still present on my SDS100, but when I hooked up an Icom HT to the exact same antenna, the interference issues were no longer present. Both radios were running on battery power. Both radios were tested by driving around the same area.
The best way I can describe the interference is rapid variations in the noise floor causing normally reasonably strong transmissions to become very noisy and often cut in and out. Here is an example: SDS100 interference
This does not happen when the vehicle is stationary or when using the SDS at home.
Any ideas as to why this happens on my SDS, but not my Icom?
